				09 Vibe lost cup inserts, and floormats
				Posted: Sun May 13, 2012 5:51 pm
				by MannyL
				I lost the inserts that go in the center console to hold cups. If someone can tell me the dimensions of them I could fabricate some out of foam.
Also the driver's side floor-mat is ragtag on the upper left side. I want to replace it with one that will attach to the hooks. Any suggestions?
Thanks in advance
				Re: 09 Vibe lost cup inserts, and floormats
				Posted: Sun May 13, 2012 5:57 pm
				by vibenvy
				Check
car-part.com. I'm sure you could easily find a junkyard near you with a 2009+ Matrix or 2009-2010 Vibe to grab the cup holder inserts from for cheap.
As far as the floor mat goes, I recommend getting some rubber ones. They hold up much better than the carpeted ones and are much easier to clean.
				Posted: Sun May 13, 2012 6:17 pm
				by MannyL
				J_TO_ENVY wrote:Check
Do they make rubber ones with the holes for the clips?
				Posted: Mon May 14, 2012 10:28 am
				by ponta2147
				MannyL wrote:J_TO_ENVY wrote:Check
I know the WeatherTech ones do. I assume the factory rubber ones would as well.
				Posted: Tue May 15, 2012 4:56 pm
				by vibenvy
				MannyL wrote:Do they make rubber ones with the holes for the clips?
Yes. I have the GM Accessories Premium All Weather Floor Mats and they do have the holes for the clips on the driver's side. I also believe the Husky Liners floor liners and floor mats have them as well, in addition to the WeatherTech ones that ponta2147 mentioned.
				Posted: Tue Aug 28, 2012 9:51 pm
				by MannyL
				I'm still looking for the cup holder no luck so far.
 As for floor mats I got some carpeted ones that didn't have the holes and a coworker put them  in and added grommets.
				Posted: Wed Aug 29, 2012 7:33 am
				by trb
				MannyL wrote:I'm still looking for the cup holder no luck so far.
I have a set of the dividers I pulled from a 2010 at a salvage yard close by me.  The other person I offered them to has not been back on here for over a month, so if you want them, send me your address via PM.
				Posted: Thu Sep 20, 2012 8:00 pm
				by MannyL
				trb wrote:MannyL wrote:I'm still looking for the cup holder no luck so far.
Parts arrived and fit perfect now my coffee won't spill any more. Just need to resolve my audio issue now.
