Vaggeto's Garage (2003 Vibe AWD Shadow)
Posted: Sun May 13, 2012 3:28 am
Hi everyone,
I know I'm quite late to the party. I've read genvibe.com a few times over the years for advice on a few things, but just recently actually got into doing car work/maintenance myself. Before now I would say I neglected due to ignorance and lazyness, many small aspects of car maintenance. Thank God after 9 years the car is great and I love it more than ever. Now I've really got the bug and I've spent many hours recently reading/working on the car. Almost everything I've done is the 1st time for everything, and this forum has helped tremendously.
Vehicle Information:
2003 Pontiac Vibe. Shadow color. AWD. Moon & Tunes package. 107,000 miles as of 4/2012.
Work/maintenace done myself worth mentioning starting in April 2012:
More pictures are below, I'll continue to add to them as things progress. I'll add comments above each picture as a description.
Here she is when we got her back in April, 2003. (Sadly she's nameless)
- Got new key & key FOB made for a lost set. Bought FOB from ebay for ~$20 and used directions easly found here to program FOB to my car. Dealer wanted like $120+. (1/10 difficulty.)
- Fixed visor. (painted new screws for one lost one). (1/10 difficulty.)
- Replaced headlights & fog lights. 3/10 difficulty.
- Replaced front wipers. (Free after rebate! RainX Fusions) (1/10 difficulty)
- Replaced in-cabin air filter. (1st time!, was only brown, not black). (1/10 difficulty)
- Cleaned MAF sensor. (1/10 difficulty)
- Replaced Spark Plugs. (1/10 difficulty)
- Replaced rear differential fluid. (1/10 difficulty)
- Replaced transfer case fluid. (1/10 difficulty)
- Drain + Fill'd trainsmission fluid & replaced filter. 3 drains total. (2/10 difficulty)
- New wheels from Discount Tire Co. (16" Konig Zero-In)
- New Goodyear Gatorgrip serpentine velt. (3/10 difficulty)
- Fixed oil leak on timing belt tensioner by removing and replacing rubber o-ring. (2/10 difficulty)
- Adjusted Climate Control cable for better AC. (It worked!) (1/10 difficulty)
- New front glass. First time in 9 years. (from local business)
- Replaced all 4 struts and strut mounts. (Fronts 5/10 difficulty, rears 6/10 difficulty)
- Replaced both side rear differential axle seals. (5/10 difficulty)
- Alignment from local business.
- Replaced power steering fluid.(2/10 difficulty) Tutorial Here
- Replace PCV valve. (1/10 difficulty) Experience Here
- LED lights in the cabin interior. From Ebay for about $10 shipped. (1/10 difficulty)
- New hood struts. From Ebay for $46 shipped. (1/10 difficulty)
- Clean/Detail Engine
- Fix lights in stereo display. #1 & #3 are out.
- Fix right climate control light. Must tap repeatedly to get working.
- AC Foam on AC lines. Red zip-ties. (Possibly better AC)
- Install new brakes.
- Paint calipers red. (Maybe some accent on the drums as well)
- Get retainers for fender liners/lower engine covers. (most are gone somehow)
- Replace both R&L inner fenders. (worn through in parts due to missing retainers over time)
- Replace lower left engine cover. (lost on the highway due to retainers breaking off over time)
- Replace front lower/upper bumper cover. + 1 lower right grill) (Slid into small loose brick wall in 2010/2011 winter)
- Replace front license plate mount & license plate.
- Replace brakes.
- Fix cabin air clicking. (Hopefully just rotate gear 180 degrees.)
- Top or back spoiler (thinking Top currently)
- Replace VVT Oil Filter.
- Install sound deadening material. (Roofing sealent + Roxul Safe'n'Sound in floor. Possibly doors too)
- Restore headlights, possibly retrofit HIDs.
- Get door/window recall done. (Should I at this point?)
- Get windows tinted. Either 27% or 35%.
- Grafxworks Black or Black Carbon fiber overlays on all badges and emblems.
- Paint Engine cover + Exhaust cover + fuse box (Possibly red?)
- Fix half broken hinge on armrest.
- Some type of back mat.
- Somehow (tips wanted) restore the black plastic pieces on the outside of the vehicle.. The side view mirror housing, between doors, etc)
- Fix stereo buttons that are scratching off somehow.
