The CompNine VIN Decoder is back!
Posted: Tue May 08, 2012 5:31 pm
by vibenvy
I just read this on another forum and figured I'd share it...
Re: The CompNine VIN Decoder is back!
Posted: Tue May 08, 2012 5:57 pm
by crazytrain
Cool. Just found out my Vibe was built 2006-06-26. Purchased 2006-07-22.
Found 56,128 vehicles matching your year and model in our database.
There are 3 2006 ALL PURPOSE 4 DR VIBE vehicles (0.005%) matching your exact options list. <----Don't I feel special :mrgreen:
There are 8 (0.014%) with at least as many options.
Posted: Fri May 11, 2012 12:08 pm
by klindstedt
Huh. My Vibe was an Enterprise Rent-a-car :(
221 other Vibes like it. At least I was able to confirm that I should have keyless entry. Just need to find some transmitters now...
Posted: Fri May 11, 2012 1:08 pm
by Cougar Vibe
I'm still not convinced these VIN decoder websites are all that accurate. Last time someone posted one on here, it said there were three matches to my option list (which happens to be an '05 90U AWD); I knew that was B.S. based upon seeing more than three Gray Metallic AWD's between Maryland, Pennsylvania and Washington. Now I run my VIN, sort via options and it returns fifty similar models. While that's better than the previous results, I just can't believe that there are only 49 AWD 90U Vibes like mine...
Posted: Fri May 11, 2012 4:33 pm
by vibenvy
Cougar Vibe wrote:I'm still not convinced these VIN decoder websites are all that accurate. Last time someone posted one on here, it said there were three matches to my option list (which happens to be an '05 90U AWD); I knew that was B.S. based upon seeing more than three Gray Metallic AWD's between Maryland, Pennsylvania and Washington. Now I run my VIN, sort via options and it returns fifty similar models. While that's better than the previous results, I just can't believe that there are only 49 AWD 90U Vibes like mine...
Well, the thing is is that not every Vibe that's the same color as yours has the exact same options. For example, my silver 2009 Vibe GT: according to CompNine, there are 7 other silver 2009 Vibe GTs with the exact same options as mine. This means that while I may see quite a few other silver 2009 Vibe GTs, they may not have the Theft-Deterrent System as mine does, or they may be a manual transmission whereas mine's an automatic, but somewhere out there there are 7 other silver 2009 GTs that have the Theft-Deterrent System, are automatic, etc. just like mine. There's alot more then exterior appearance i.e. color, wheels, etc. that goes into a vehicle ;).
Posted: Fri May 11, 2012 5:53 pm
by Cougar Vibe
While that's true for the base and GT models, the 1st gen AWD's all came w/the same options (A/T, Moon & Tune, 16" wheels, etc.), short of traction control and leather (which I'm not even sure you could get on the AWD's); the only differentiation from one AWD to the next was the exterior color. To put it another way, the AWD's came pretty much loaded, so it came down to color choice when buying one. And being as the 90U color code was one of the three most common paint schemes, I'm still not buying the accuracy of their database.
M_C
Posted: Fri May 11, 2012 6:04 pm
by vibenvy
Cougar Vibe wrote:While that's true for the base and GT models, the 1st gen AWD's all came w/the same options (A/T, Moon & Tune, 16" wheels, etc.), short of traction control and leather (which I'm not even sure you could get on the AWD's); the only differentiation from one AWD to the next was the exterior color. To put it another way, the AWD's came pretty much loaded, so it came down to color choice when buying one. And being as the 90U color code was one of the three most common paint schemes, I'm still not buying the accuracy of their database.
M_C
I'm not too familiar with the 1st gen Vibes, so thanks for that info ;). That does make sense then.
J_TO_ENVY wrote:Yeah, it's not always exact with everything, but it's close enough to be interesting at least. Here's what it says regarding the color of my Vibe:
EXTERIOR COLOR,BLUE FROST MET (20U)
EXTERIOR COLOR,PRIMARY (20U)
PRIMARY COLOR EXTERIOR, IMPRESSION BLUE(09)(GMDAT) (20U)
PRIMARY COLOR EXTERIOR, PRESTIGE BLUE, MET (05) (SGM) (20U)
Clearly my Vibe is not anywhere near any shade of blue, but what's weird is the color code (20U) is correct. Go figure :roll:.
The accuracy is definitely debatable, but at least you can find out stuff like the exact day your Vibe rolled off the production line, etc. It's interesting at the very least.
Posted: Mon May 14, 2012 6:02 am
by ehoff121
Now that I have my account working again, I'll post my search results.
Vehicle: ALL PURPOSE 4 DR AWD VIBE
Year: 2005
Build Date: Unk.
Found 8,725 vehicles matching your year and model in our database.
RPO Description
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
U1P RADIO AM/FM STEREO,SK/SCAN,CD,CLOCK,EQLZR,RDS ETR STEREO W/CD,CLK,EQLZ(U1P)
U16 TACHOMETER,ENGINE TACH(U16)
U2K DIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
U65 SPEAKER SYSTEM 7,PREMIUM 7 SPKR SYSTEM,PREMIUM(U65)
VBY MODEL CONVERSION PONTIAC VIBE ALL WHEEL DRIVE PONTIAC VIBE AWD(VBY)
VM3 LABEL INFORMATION CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 5 MPH & RR 5 MPH 5 MPH BUMPER INFO LABEL(VM3)
V35 BUMPER FRT & RR,COLOR COLOR FRT & RR BPR(V35)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
XR5 FILTER POLLEN POLLEN FILTER(XR5)
Z05 COMFORT AND CONVENIENCE PACKAGE COMFORT & CONVENIENCE PKG(Z05)
COMFORT AND CONVENIENCE PACKAGE(MERCHANDISING OPTION) COMFORT & CONVENIENCE PKG(Z05)
1SA PACKAGE-OPTION 01 (1SA)
SALES PACKAGE SALES PKG(1SA)
1SZ PACKAGE OPTION- (1SZ)
14U EXTERIOR COLOR,LT GRAY MET (14U)
EXTERIOR COLOR,PRIMARY (14U)
PRIMARY COLOR EXTERIOR, SILVER MICA MET (14U)
PRIMARY COLOR EXTERIOR, TEAL BLUE (04) GMDAT (14U)
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C)
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AN4 RESTRAINT PROVISIONS,CHILD(CANADIAN) CHILD RST PROVISIONS(AN4)(CANADIAN)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AU4 LOCK,SIDE DOOR,ELECTRIC,AUTOMATIC AUTO ELEC S/D LK(AU4)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
B37 COVERING,FLOOR MATS,FRONT AND REAR AUXILIARY FRT/RR AUX FLR MATS(B37)
B56 MOLDING ROCKER BODY COLOR,ROCKER MOLDING BODY COLOR ROCKER MLDG(B56)
MOLDING ROCKER BODY COLOR,WIDE ROCKER MOLDING AND LOWER DOORS LWR DOOR & ROCKER BODY COLOR MLDG(B56)
ORNAMENTATION,EXTERIOR,ROCKER PANEL MOLDING COLORED RKR PNL MLDG(B56)
B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE) DELUXE EXTR TR(B57)
B71 ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(BLACK) W/H MLDG(B71)
ORNAMENTATION,EXTERIOR,WHEEL OPENING MOLDING(COLOR) W/H MLDG(B71)
CF5 ROOF,SUN,GLASS SLIDING,ELECTRIC ELEC SUNROOF(GLASS)(CF5)
C2H PORT OF ENTRY - FREMONT, CALIFORNIA, USA
C25 WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DG9 MIRROR I/S R/V TILT, DUAL READING LAMPS, VEH COMMUNICATION,SYS CONT I/S MIR W/DUAL READING LAMPS & VEH COMM(DG9)
D48 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR ELEC R/CON PAINTED O/S MIR(D48)
D75 HANDLE O/S,DR,BODY COLOR O/S BODY COLOR DR HDL(D75)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
FV6 RATIO TRANSAXLE FINAL DRIVE 4.24 4.24R(FV6)
JM4 BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
LV6 ENGINE-GAS, 4 CYL, 1.8L(1.8-8),MFI 1.8-8(LV6)
MU5 TRANSMISSION AUTO 4 SPD, AISIN-TOYOTA, PTU 4-SPD A/TRANS(MU5)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
NBG ACCESSORY PACKAGE - # 7
NBH ACCESSORY PACKAGE - # 8
NT9 EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT TIER 2 PHASE-OUT FED EMIS(NT9)
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
N41 STEERING,HYDRAULIC(VARIABLE RATIO) P/S(N41)
N65 WHEEL AND TIRE,SPACE SAVER SPARE,STEEL STEEL SPACE SAVER SPA(N65)
PCR CONTROL - SALES ITEM NO. 111
PDE CONTROL - SALES ITEM NO. 122
PDG CONTROL - SALES ITEM NO. 124
PDN CONTROL - SALES ITEM NO. 131
QD2 WHEEL 16 X 6.5, ALUMINUM, 5 SPOKE STYLED ALUM WHEEL(QD2)
QGF TIRE ALL 205/55R16-91H BW R/ST TL HWY TIRE(QGF)
R9P CONTROL - SALES ITEM NO. 90
T61 LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61)
T82 HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82)
Rarity...
Posted: Mon May 14, 2012 10:44 am
Don't know if this was the same decoder link posted here on GenVibe a couple years ago or not BUT it will not change the "match" quantity when I switch optional equipment from the left column to the right. Thus this program is not showing me the true "rarity" of my Vibe. I do remember doing this a couple years ago and it was interesting to see the results. Since mine is the GT and has a manual transmission, it is one of the rarest 09 Vibes out there :?
