Front Axle(s) Replacement
Posted: Sun Apr 29, 2012 5:10 am
I would like to obtain some feedback from the Gen Vibe Community for this suggested repair.
I have a 2004 Vibe with the 1zz engine, auto trans and about 115,000 miles. I am the second owner and purchased the car with about 94k miles.
I have been chasing an intermittent vibration since we purchased the car two years ago. The vibration is mainly in the front of the car felt in the steering wheel. I installed 4 new tires when I purchased the car and have had them balanced several times. Each the vibration went away for a while but then returned. The major chain tire dealer after prompting to look deeper into the vibration said one of the rims were bent. After that, I took it to my local mechanic as I didn't have confidence in the major chain tire dealer.
We put the car on a lift, took off the front tires and accelerated the car to about 50 MPH. You can hear a rumbling in the front end and when looking at the front axles, they are not spinning concentrically which seems to be causing the vibration. You can also tug on the axles and there is a lot of play where the axle goes into the transmission case. My mechanic said the pinion gear ( I think this is right but not sure) appears to be worn or damaged and not holding onto the end of the axles which is causing them to vibrate. He also said the axles themselves may also be worn but he wouldn't know until he disassembled the front end and checked them for play. My mechanic also checked his auto database for any common issues with the Vibe / Matrix regarding this issue and while he saw a few cases, it wasn't a common problem. We also saw some signs after the car was on the lift that the vehicle may have been in an accident so I guess there is a possibility that it was hit in the front end or hit a curb etc which could have caused the play in the axles
So my mechanic is suggesting we pull the axles and transmission and he can rebuild the unit and also check the axles and if worn, replace them as well. I am trying to decide if it makes sense to put this amount of money into the car given the age and mileage. Other then this, the car runs great, the engine is tight and doesn't burn any oil and the interior is very clean.
Does anyone have any examples where they have pulled their axles and found play where the axles goes into the transmission and do they think this will fix the problem?
Thanks in advance for any comments.
Jeff Breeden
Jeff Breeden
