Please use original thread - 2003 Vibe GT Partout Repost
Posted: Wed Apr 25, 2012 9:10 am
Reposting my Partout
Parting out 2003 pontiac Vibe GT -same as Toyota Matrix XRS -
NO DRIVETRAIN! - (have both 1zz and 2zz disasembled both with bad blocks but accessories and top end should be all available)
________________________________________________________________________________________________________________
single cd player (good condition) - 6 disc also available but buttons are rubbed off
radio bezel w/ switches
gauge cluster and chrome bezel (175k mi m/t)
d/s vent w/ switch
Shifter surround - Leather Shift boot sold<br>
Celica gts steering wheel - needs some clean up but good leather
2x complete columns w/ ignition lock + keys,
2x clock spring
celica gts column aux controls
Vibe aux controls:
2x Wiper control stalks (intermitent) - lighting stalk sold
Cruise Control Stalk
cruise control unit and module w/ throttle cable - control lever also available
abs pump
front calipers (2x rear 00 celica gts rotors and one caliper available)
brake booster and master cyl
hood release handle, cable and latch
gas door, cap, handle + cable
- also 1zz ecu (m/t 03 corolla s cruise no abs) and harness(alternator plugs cut otherwise intact)
front and rear lighting relays/ modules - fuse box misc electrical relays modules etc
cruise relay / module
115v invertor from under p/s seat and dash piece (no outlet cover)
rear bumper blue (neptune blue or unpainted gray) w/ reverse lights
upper and lower spoiler - black
p/s/f + d/s/r black doors w/ interior panels
(p/s/f door glass sold)
d/s/f dark blue door
- all power w/ color match cladding (additional black and unpainted cladding also available)
Painted power mirrors d/s blue p/s black
(p/s/ fender and d/s + p/s rear black
cladding also good)
__________________________________________________________________________________________________________________________
Drivers front door w/ vibe badge - dark blue (neptune)
I have d/s master switch w/ broken tab
P/s switch
Pass front w/ badge & both side rears - black (abyss) w/ gt badge w/ switches.
Door panels :
also sunroof glass / motor, switch (dome lights)
washer resovoir w/ f+r pumps
glove box, d/s change compartment
double lid center console
- cupholder, armrest shifter console all broken and thrown out
p/s sun visor, 2x oh S#!t handles
black gas door w/ cap - reads premium fuel only
- drilled out needs to be riveted on to install (worked great for my broken hinge)
Rear plastic cargo floor/ seat backs in good shape
3rd brake lamp (no cover)
Spare tire + 16" steel wheel
Airbags: passanger front and sides with 2x modules(for front only or with side bags) / 2x clock springs also avaialble
***not for sale in new york out of state sales only
- More RANDOM parts as well please CALL
also have:
2003 Corolla S w/ cruise no abs 1ZZ-FE 5 speed ecu + harness - missing alternator plugs (p/n 89666-02133)
00 Celica GTS Leather Steering Wheel decent condition, some paint splatter should clean off (no airbag)
- gts Starter and alternator / oem amp / rear rotors / p/s/r caliper/ steering column / fuse box / partial harness
Prime Goodies sold or No Good:
Front end wrecked: bumper/ rad/ support/ fenders hood /lights / fogs/ plate mount
Rear gate/ interior hatch plastics/ tail lights (have d/s with slight crack)
Seats - rear seat plastic backs available
alloys gone 3/4 steel wheel gone
chassis is cut up and scrapped
p/s/r door + p/s/f window sold
Roof Rack cross bars / end caps sold
2zz bottom end 2zz ecu/ wiring harness
1zz block - have 3x rods pistons and crank condition unknown
C60 6 speed trans(bought an C65 MR-S rear clip may have another C60 available once spyder is assembled)
rear disc conversion and rear beam - brakes ebrake cables etc
Manual conversion parts, pedals, shifter (have a broken shifter usable for project but it's stripped and shaft spins)
Located on Long Island NY local pickup NYC area/ PA/NJ for gas $ consideration
in Port Jefferson - directly opposite Bridgeport Ferry for Conn/ New England folks
or Shipping is good too
Michael
Txt pm or email
631-806-5350
badg04t@gmail.com (also paypal)
d/s vent w/ switch
2x clock spring
Vibe aux controls:
abs pump
cladding also good)
P/s switch
Door panels :
also have:
Michael
Txt pm or email
631-806-5350
