Bilstein HD shocks and struts?
Posted: Fri Apr 20, 2012 6:49 pm
by publicacct
I know the Matrix and Vibe are basically Corolla wagons. Are their shocks and struts interchangeable? That is, can you use Corolla struts on a non-AWD Matrix, Vibe, or Voltz 2003-2006?
Like these Bilstein HD shocks and struts:
http://cart.bilsteinus.com/search/mmid=1432914
Re: Bilstein HD shocks and struts?
Posted: Sun Mar 11, 2018 3:36 pm
by publicacct
on a similar note, has anyone tried the Koni inserts for the Corolla? These are the ones that require cutting the original strut and inserting the Koni cartridge. Again, Koni makes them for the Corolla but not the Matrix/Vibe. But you can probably cut an OEM Matrix/Vibe strut open and install the Koni insert, if the OEM Matrix/Vibe struts are the same diameter as the OEM Corolla struts.
If they would fit, then you wouldn't have to do anything to a Matrix or Vibe that you wouldn't have to do to a Corolla.
If you install the Bilsteins on a Vibe, you need to widen the two bottom holes since they use bigger bolts than the Corolla uses.
So, will either one fit?
Posted: Sun Mar 11, 2018 3:50 pm
by SeattleJeremy
Wow. I messed up last time I looked at the Bilstein website. Turns out they have made parts for the Corolla.
https://us.bilstein.com/en/product-sear ... 8667319091
So...
https://www.monkeywrenchracing.com sells Bilstein parts for Lotus, I wonder if they are able to get the Corolla struts.
Posted: Tue Mar 13, 2018 11:08 am
by ImUrOBGYN
Love Bilsteins. On my Supra. Let us know what you come up with.
Posted: Wed Mar 14, 2018 10:46 am
by SeattleJeremy
I did some more research, and found that the rear struts are the same for Corolla and Vibe/Matrix FWD. However, the front struts are different in small ways.
Posted: Sun Mar 18, 2018 5:29 pm
by treesleavedents
but will they fit?
Posted: Tue Jul 03, 2018 9:43 am
by bratboy
It's unfortunate that this topic hasn't been followed up on. so...
Koni will do batches of custom suspension kits.
what are the differences between our cars and the Corolla struts? Can they be modified?
What are the OEM dampening specs between our cars and the the Corolla? If they are the same, and mods can be made then we have a shot.
Posted: Thu Jul 05, 2018 3:59 am
by zbyers
..this post is 6 years old. Corolla struts do fit, they need some of the holes widened a bit because they use smaller diameter bolts to mount the struts.
Posted: Sat Jul 14, 2018 7:05 am
by bratboy
zbyers wrote:..this post is 6 years old. Corolla struts do fit, they need some of the holes widened a bit because they use smaller diameter bolts to mount the struts.
That's great to hear. Do you know of anyone on here that did the Bilstein or other performance suspension install? I couldn't find someone who did it and would like to hear some reviews.
Posted: Mon Jul 16, 2018 3:40 am
by zbyers
99% I've seen get KYB struts or Tokico (spelling?) though the latter are hard to come by now.
Posted: Sat Jul 28, 2018 12:22 am
by bratboy
Can someone post pictures of the modifications to the suspension ? I'd like to have a look at this. And see if there is a better smarter option to use instead of OEM stuff
Posted: Mon Jul 30, 2018 2:40 am
by zbyers
These are 15+ year old cars. If these were an option, someone would have used them by now....
Posted: Sat Apr 27, 2024 5:28 pm
by vibevic
I have the Corolla Bilsteins on my 07 Vibe and love them. What an improvement over Koni.
