gas tank pressure 03 Vibe
Posted: Fri Apr 20, 2012 3:57 pm
by danielg9
Check engine light indicates bad gas cap or pressure sensor bad. Changed gas cap with Pontiac factory and still get check engine light. Any experience with faulty pressure sensor and how involved is it to replace. Thanks. Dan in Montana
Re: gas tank pressure 03 Vibe
Posted: Sat Apr 21, 2012 9:46 pm
by Herb
Did you reset the computer? The error code can stay in memory for a bit after you correct the problem.
