tire loss
Posted: Sun Jul 13, 2003 6:36 am
by SkateForLife86
I've had my car for like month (only like 5,000 miles) and my front tires have lost so much tread compared to the rear tires. I don't burn out much at all. Is it possible to lose some tire tread from redlining first and second gear a lot? When the weight transfers from the front to the rear and the front lifts a little, could that cause more loss of rubber? I have Falken Ziex's right now.thanks
Re: tire loss (silverawd26)
Posted: Sun Jul 13, 2003 10:37 am
by dmitri
i want to see your custom exhaust too if possible.
Re: tire loss (SkateForLife86)
Posted: Mon Jul 14, 2003 2:24 am
by KSNeptune
a) Stock tires on new cars are usually crap.b) The front tires are the drive tires. So Yes, they'll wear faster.c) It's slightly possible you need an alignment. Wheels not alighned will devour tires.d) You've been squeeling those tires, haven't you! That black streak on the pavement is your tread.From the above you may pick any one or more options, whichever relate to your driving style.KSNeptune
Re: tire loss (KSNeptune)
Posted: Mon Jul 14, 2003 4:53 am
by Sub-Vibe-R
quote:a) Stock tires on new cars are usually crap.quote:I have Falken Ziex's right now.So he does not have stock tireAnd take a look to his mod: quote:-18" Tenzo R So for sure he does not have stock tire anymoreBut I agree with you, usually stock tire are the best you can have.
Re: tire loss (Sub-Vibe-R)
Posted: Mon Jul 14, 2003 1:42 pm
by wildvibe
Remember every 6,000 get those tires rotated
Posted: Tue Jul 15, 2003 6:44 am
by dmitri
after u got those bigger wheels did you do an alignment?
Re: tire loss (dmitri)
Posted: Tue Jul 15, 2003 8:45 am
by SkateForLife86
yea i got them aligned
Posted: Tue Jul 15, 2003 2:06 pm
by SkateForLife86
yep i got the ole 5speed base model.
Posted: Tue Jul 15, 2003 11:12 pm
by Sub-Vibe-R
Do you have "Z" reated tire???Z tire will wear faster then regular R tire, as the rubber is softer and they stick more.
