Eco Modding, any tips?
Posted: Sat Apr 07, 2012 8:01 am
by colterk
Anyone know about eco modding or how to 'eco-mod' our cars. What can I do to help MPG? What're your thoughts? http://ecomodder.com/
Re: Eco Modding, any tips? (colterk)
Posted: Sat Apr 07, 2012 8:12 am
by star_deceiver
Teach yourself to drive more conservativly. Let's face it, you can do a lot to the car to give it the potential to achieve better fuel efficiency but if you can't contol your right foot then you're still going to get only so-so mileage.Take mine for example. My last tank was 31.3mpg 70/30 highway. If I drove carefully and with due control of the throttle I can easily get 36+... but I don't usually...
Posted: Sat Apr 07, 2012 8:20 am
by KITT222
Grille blocks. I have one in my upper grille (behind the plastic) and one for the lower which I use in the winter. I used to have an air dam, too. Now I want to get a belly pan under there.
Re: Eco Modding, any tips? (KITT222)
Posted: Sat Apr 07, 2012 11:30 am
by vibenvy
Quote, originally posted by star_deceiver »Teach yourself to drive more conservativly. Let's face it, you can do a lot to the car to give it the potential to achieve better fuel efficiency but if you can't contol your right foot then you're still going to get only so-so mileage.Take mine for example. My last tank was 31.3mpg 70/30 highway. If I drove carefully and with due control of the throttle I can easily get 36+... but I don't usually...x2When accelerating, try to keep your RPMs under 2500. Make sure your tires are properly inflated.Keep up with maintenance i.e. oil changes, air filter, etc.
Posted: Sat Apr 07, 2012 11:44 am
by ColonelPanic
ScanGauge. Get lots of coroplast. Make yourself those grille blocks and a belly pan.. Daox had a build thread (you can see his thread on ecomodder too.) Should give you an idea of things that you can try.http://forums.genvibe.com/zerothread?id=28781
Posted: Sat Apr 07, 2012 7:02 pm
by colterk
What is it about grille blocks that helps the mpg? Is it simply wind resistance? I'm a noob with this stuff, sorry.
Posted: Sun Apr 08, 2012 2:51 am
by KITT222
Think of the grille like big holes in your bumper. That's actually essentially what they are. Now think about what is behind them: the engine and firewall. Two big flat walls. Air just smashes into them, pushing the car back. Grille blocks keep air from entering the engine compartment which could cause more air resistance.
Posted: Sun Apr 08, 2012 11:23 pm
by colterk
Can that mess with the engine overheating? Or is that a fallacy?
Posted: Mon Apr 09, 2012 1:52 pm
by Serj22
At my work we used 4x8 panels of coroplast to cover a fence for construction. We still have about 20 of them that are getting thrown away. If anyone was nearby that wanted some in the bay area, CA, I may be able to "salvage" some of them. No promises. Don't know if they could really be shipped to WA, you'd be better off buying them.
Posted: Mon Apr 09, 2012 3:06 pm
by KITT222
Quote, originally posted by colterk »Can that mess with the engine overheating? Or is that a fallacy? Fallacy. The engine fan would go on before that, but if only the upper grille is blocked you should be okay. If the fan starts to activate just slowly cut it away to perfect. Quote, originally posted by Serj22 »At my work we used 4x8 panels of coroplast to cover a fence for construction. We still have about 20 of them that are getting thrown away. If anyone was nearby that wanted some in the bay area, CA, I may be able to "salvage" some of them. No promises. Don't know if they could really be shipped to WA, you'd be better off buying them.I think it might be possible to actually mail coroplast without any packaging. I'm not sure, but it's worth asking...
Re: (Serj22)
Posted: Mon Apr 09, 2012 5:44 pm
by colterk
Quote, originally posted by Serj22 »At my work we used 4x8 panels of coroplast to cover a fence for construction. We still have about 20 of them that are getting thrown away. If anyone was nearby that wanted some in the bay area, CA, I may be able to "salvage" some of them. No promises. Don't know if they could really be shipped to WA, you'd be better off buying them.If you could get some to WA that would be very cool. Let me know.As long as it doesn't affect engine performance in a negative way I am down for trying new things and adding to my projects list.
Posted: Tue Apr 10, 2012 2:38 am
by northvibe
Quote, originally posted by colterk »Can that mess with the engine overheating? Or is that a fallacy? if you do not, block the lower grill and have a underbody pan you should be okay. If you start doing the underbody pan you will want to fence or box off the lower opening so air only goes on the radiator. Otherwise under high ambient temps and high engine temps you will be trying to over heat. This is the same for racing. Lots of people put cardboard over wheel fender parts, swoop the back end out etc. But a lot is the way you drive, I agree.
Re: Eco Modding, any tips? (northvibe)
Posted: Tue Apr 10, 2012 7:47 am
by Serj22
Oh and also there will be about 200 more available come summertime. Again, I'll see what is allowed to be taken. As for mailing, currently in the process of finding out how and if it is possible, and I'll let everyone know.
Re: Eco Modding, any tips? (Serj22)
Posted: Wed Apr 11, 2012 7:01 am
by colterk
Quote, originally posted by Serj22 »Oh and also there will be about 200 more available come summertime. Again, I'll see what is allowed to be taken. As for mailing, currently in the process of finding out how and if it is possible, and I'll let everyone know.That would be awesome, please keep us updated. Thanks.
Posted: Wed Apr 11, 2012 10:19 am
by Serj22
Ok, so they said I could have it since we're trying to clean up all the maintenance areas where I work to make the place look better. They stored them somewhere and now I just have to find em. Shouldn't be too hard. I have a friend whos wife works as a manager for a UPS store and she said it would be possible to ship as-is. So I'll work out some kinda reasonable price. I just got to find them now.
Posted: Thu Apr 12, 2012 5:20 am
by A Psycho Martyr
not this More pics here
Posted: Thu Apr 19, 2012 12:29 pm
by colterk
A Psycho Martyr wrote:not this More pics here
Yea that is horrendous looking. I'm sorry.
