anyone have access to a parts Catalog?
Posted: Sat Mar 31, 2012 4:25 am
by woodyg
for the car in my sig, it is AWD. I am trying to find the part # for the exhaust gasket and Bolts that connect the pipe to the exhaust manifold. I appreciate any help........napa sold me a bolt kit #36454 I think that is the right kit.......but they sold me a gasket #31639 I am pretty sure that is the wrong part......here is a diagram........the part is called a ball joint on the image
http://imageshack.us/photo/my-...x.jpg/
Posted: Sat Mar 31, 2012 11:40 am
by Old Tele man
...try this GM parts website:
http://parts.nalleygmc.com/
Posted: Sun Apr 01, 2012 10:35 am
by Water boy
Ball joint is an odd name for a gasket.But, since the joint is held in place with spring loaded bolts and it flexes....
Re: (Old Tele man)
Posted: Sat Apr 07, 2012 10:58 pm
by woodyg
. I just replaced the seal=aka=exhaust gasket, that connects the pipe to the exhaust manifold. it took about an hour on car ramps fumbling around for the right sockets and extensions,etc. The old Bolts were 13mm and then new ones i got were 5/8. No body seem to have or know the exact part I needed. I did some research and the original gasket was a common fail so they designed an improved one. I bought it at the dealership. I also should have bought another bolt kit and maybe the "seal" that connect the 2 pipes about 2 feet down from the manifold. I was able to get the seal in place but in the end it would have been easier to remove the entire 2 foot pipe pipe and install 2 new seals......thanks again for the help
