Backup camera system for 2009 Vibe
Posted: Tue Mar 27, 2012 4:17 am
by MikeFAA
I am about to purchase a 2009 Vibe. I would like a backup camera system that will not disable Onstar. One shop offered to replace the current Monsoon radio/CD with a different system with a camera for about $800. However, I am looking for a $300 solution. Does anyone have a recommendation?
Re: Backup camera system for 2009 Vibe (MikeFAA)
Posted: Tue Mar 27, 2012 4:23 am
by trb
You can get the add on rear view mirror systems for around $100 that attach to your current mirror. They won't interfere with the Onstar, but they might make the buttons harder to reach. You should be able to mount it in a way that the buttons are still accessable between the two mirrors though.This is one, but I've seen them cheaper on Amazon. There is also another thread on here about this.
http://www.target.com/p/Peak-R...ci_kw=PDF manual for this one:
http://www.peakauto.com/pdf/manual-PKC0RG.pdfAnd here is the thread:
http://forums.genvibe.com/zero...53185
Posted: Tue Mar 27, 2012 10:47 pm
by mr.clutch
if you like the peak system I have one that I can sell you It is still in the package un open. It uses a seperate 3.5 in. monitor (still wireless) you can put monitor on the backside of your visor.don't have time to post pict.of it now but unit mod # is PKCORB will sell for $60.00.
Posted: Fri Apr 27, 2012 7:26 pm
by firestorm
Can't figure out how to PM here. Mr Clutch - you still have the backup camera? I'd be interested in buying that from you...
