				Power Lock Serviceable?
				Posted: Tue Mar 27, 2012 12:52 am
				by Wolfman213
				I'm having an issue with both front doors and the passenger side rear door not locking all the time.  Sometimes they do, sometimes they don't.  I seen another thread that seems rather simple getting to the power locks, however, I'm not sure if they are truly serviceable.  Has anyone tried before?  I figure if nothing else, I will just get it pulled out and remove gunk and spray with WD-40 if I can find the actual actuator.Probably going to get into it tonight; just curious if anyone else has done something like this and has a clue or insight as to what to look for.***Edit: Here is the link that shows how to remove/install them and what they look like.
http://forums.genvibe.com/zerothread?id=32536
				Posted: Tue Mar 27, 2012 11:14 am
				by cptnsolo77
				Im in the same boat as you. Both my front pass & driver side locks do not work. I tried a while back cleaning the pass side out with electrical contact cleaner by spraying through small openings in the casing. After that, I would hit the switch I could hear like the motor wants to engage, but not enough to open/close. Soon after that the power lock died again. Im finally going to break down and replace at least the pass side so I wont have to reach over to unlock it for the passenger. It has become a real pain lately LOL.I found this thread as well:
http://forums.genvibe.com/zerothread?id=28836If anyone can chime in that would be great!
				Posted: Tue Mar 27, 2012 11:13 pm
				by Wolfman213
				My dad mentioned the relay could possibly be going out.  Once I find out where that is located (does anyone know???), I will replace that as I'm sure it's only a few bucks.  If that doesn't work, then I'm just going to wait to find a Vibe, Matrix, or Corolla in a junk yard or pic-a-part place and swipe the door locks from those.  I figure after having done it once now and it being super simple to remove it, it shouldn't take more than 5 minutes at a place to get it removed per door.
