Power outlet
Posted: Wed Mar 14, 2012 8:41 am
by 09vGT
Okay, so the outlet for the cigarette lighter is not working. Anything you plug in won't work. I though maybe it was a fuse, but the book says that both the cigarette lighter and the AC Power Outlet share the same fuse. The AC power outlet works, so it ain't that; the fuse doesn't look burned either. It doesn't seem to be loose or anything. What do I need to check for? I kind of need it to charge my phone/gps.
Re: Power outlet (09vGT)
Posted: Wed Mar 14, 2012 8:59 am
by KITT222
Check the wires connecting to it.
Posted: Wed Mar 14, 2012 9:34 am
by 09vGT
How do I get back there?!
Re: (09vGT)
Posted: Thu Mar 15, 2012 7:41 am
by star_deceiver
It's a pain... you may be able to get at it through the shifter. Beware though that the plastic trim pieces are fragile, tabs break easily.
Posted: Wed Mar 21, 2012 2:27 am
by pushead
I would start by checking the plugs to the inverter under your seat. If they look ok I would probe them for power both coming and going. This will set you in the direction you need to look.
