Brief engine " rattle " at cold start-up ,
Posted: Fri Mar 09, 2012 9:24 pm
by Esteban
Just to let others know, My 2010 Vibe had a brief rattle sound lasting about one second when starting with a cold engine . It sounded like the heat shield over the catalytic converter was rattling, but that wasn't it. The dealer could not hear this til I left it , overnight, & started it the next morning. I had printed out a copy of the TSB linked below, & took it with me. They heard the noise , called GM advisors, & did the repairs. They said that it was the first time they had seen this problem. There is even a short video on youtube about it. If you have this problem, it may pay you to make a copy of this pdf file when taking it to the shop. The warranty covered everything & they gave me a rental for 2 days.http://www.empirepao.com/tsb/T-SB-0087-09.pdf
Re: Brief engine " rattle " at cold start-up , (Esteban)
Posted: Sat Mar 10, 2012 1:11 pm
by Motoretro
So a GM dealer honored this with out a problem? Isn't the GM warranty 5 years/100K on this 2010 vehicle? If so are Toyota TSB's covered under GM's 5/100K warranty?Thanks, Motoretro
Posted: Sat Mar 10, 2012 9:18 pm
by Esteban
Yes, it was honored once their GM mechanics were able to hear the noise & read the bulletin I had given to them. It will be interesting to see if GM now issues the same bulletin for their Vibes. It is for the 1.8 engines.
Re: (Esteban)
Posted: Mon Mar 12, 2012 11:37 pm
by XRVibe10
GM does have a bulletin regarding this condition on the 1.8L engines (basically the same Toyota Bulletin) there is also one for the 2.4L engines with a Sharp Engine noise @ start or idle - the intake cam phaser will need to be replaced on this engine as well if traced / diagnosed as the concern
Posted: Tue Aug 14, 2012 11:01 am
by twistedwaffle
I just bought an 09' Vibe (1.8L) last week, and has been making this noise since day one. Good to know it's not a serious problem, however was hoping I wouldn't have to see a mechanic this soon. Haha
Posted: Tue Nov 06, 2012 1:28 pm
by jackiyork
Hi- I am having a similar problem. I do not have a "check engine" light on- did anyone else have the engine light come on?
Thanks- totally newbie to this stuff!
Oh- I have a 2009 Vibe GT with about 41,000 miles.
Posted: Tue May 14, 2013 4:06 pm
by ema1003
I just bought a 2009 Pontiac Vibe used, and I am also experiencing a brief rattle on the cold engine start. It only does it after the engine has been sitting several hours. Any newer updates on this? Is it covered by the 5 tear 100, 000 mile engine warranty by GM?
Posted: Tue May 14, 2013 7:34 pm
by star_deceiver
The cam phaser won't solve the problem. The problem lies within the starter. viewtopic.php?f=12&t=39658" onclick="window.open(this.href);return false;
Posted: Thu Jun 06, 2013 6:14 am
by AmandainOttawa
Esteban,
That PDF link that you posted doesn't seem to work for me, but I'm now having the same problem with my 2010 Vibe. I'm wondering if you still have that, or know where else I can get it?
Thanks!
Posted: Thu Jun 06, 2013 6:41 am
by Rayven01
Looks like this is the one: http://www.readbag.com/empirepao-tsb-t-sb-0087-09" onclick="window.open(this.href);return false;
