FS: Progress 22mm Adjustable Rear Sway Bar (Mazda3)
Posted: Wed Mar 07, 2012 10:32 am
by 06pvibe
This has been sitting around for several years now, since I installed the bigger RB bar and its time to clean up.You all know the drill by now: 22mm Progress adjustable rear bar (OE is 20mm.) Added were the aftermarket "greasable" urethane bushings. (Use only silicone grease.)Fits all '03-'09 Mazda 3 series cars, sedan or hatchback.If you want just a little more bar (or less understeer depending upon your point of view) this is the bar for you. I never had it on the light setting so I can't speak to that, but I can tell you the OE bar is 20mm and is as long as this one is.OE links work well with this bar. No need to upgrade.$60 shipped to the continental United States, or will deliver/meet in the greater north Austin area.
