Help: Need to change dash light
Posted: Tue Feb 21, 2012 2:58 am
by hypershrimp
Hello, The dash light close to the heater/AC turn knob is dead. I was wondering if anyone has changed those bulbs before and how.
Re: Help: Need to change dash light (hypershrimp)
Posted: Tue Feb 21, 2012 11:19 pm
by Wolfman213
Pop off (or at least the bottom part) the radio trim.Pop out thetrim around the shifter/HVAC area. It's all one piece. Best thing is to start down by the shifter and work your way up.Once you get it all loose, you will be able to see the bulb. If you are replacing it with a stock bulb, simply replace the bulb with no worries about polarity. If you replace it with an LED, make sure you check it first before putting everything back together otherwise you will be kicking yourself if the polarity is reversed!Now if you want to go at it blind, you can simply try and long arm it and reach behind the trim and undo the bulb and replace it with the new one. That being said, I think I had all the trim under my shifter removed anyways due to other stuff I was doing. Plus with those bulbs being so small, I would recommend not going at it blind. More time consuming, but you'll probably get it done on the first try with no probs!
