Repositioned Passenger Wiper Arm Today
Posted: Thu Jul 10, 2003 11:19 am
by Vibe
Today I finally repositioned that passenger wiper arm that used to point at the sky. Looks much better-makes the car look more streamlined. A real simple fix. Tommorrow--I will disable the daytime running lights. Then give her a super coat of wax. James( Vibe)
Re: Repositioned Passenger Wiper Arm Today (Vibe)
Posted: Thu Jul 10, 2003 4:40 pm
by Geo
Nice work, James :DIt's the little things that seem to count the most, no?Good luck with the DRLs, it's a (removed) getting down under there
Posted: Thu Jul 10, 2003 11:54 pm
by pwarren4
quote:Today I finally repositioned that passenger wiper arm that used to point at the sky.Please elaborate on what you did and how you did this.Thanks
Re: Repositioned Passenger Wiper Arm Today (pwarren4)
Posted: Fri Jul 11, 2003 1:52 am
by NovaResource
quote:Please elaborate...If you stand in front of your Vibe and look at the 2 wipers while parked, you will notice that the passenger side blade is higher up and on a slight angle due to the higher park position. What James (and I) did was to reposition the passenger side arm slightly lower so it parks lower and level with the driver side blade.To do this, remove the small plastic cap at the pivot point of the passenger side wiper arm and remove the nut holding the arm to the stud. Then remove the wiper arm from the stud and re-install it lower and level to the driver side blade. Re-install nut and cover and you're done.
Re: Repositioned Passenger Wiper Arm Today (NovaResource)
Posted: Fri Jul 11, 2003 2:03 am
by pwarren4
Thanks, I'll have to check mine out
Posted: Fri Jul 11, 2003 2:40 am
by Vibe
Thanks for jumping in and providing an answer. I am not the best a typing and you saved me some time.Yes --It looks better --I noticed that the day I picked up my Vibe and thought it was just mine until I looked at others.I might add that I also put a VERY VERY little drop of loctight on the nut since sometimes removing a fastener takes away from the original snug fitting threads. James
Posted: Sat Jul 12, 2003 2:29 am
by huy397
Hmmm... it does stick out a little bit...Can you please post some pics of your end results ?from inside and outside of the car if possible..thank you
Re: Repositioned Passenger Wiper Arm Today (silverawd26)
Posted: Sat Jul 12, 2003 10:57 am
by Vibe
Sorry I didn't feel the need to take pictures. James
Re: Repositioned Passenger Wiper Arm Today (huy397)
Posted: Sat Jul 12, 2003 11:17 am
by Sputnik
Here's a photo that pmh013 took after repositioning her vibe's wiper blade.
http://forums.genvibe.com/zerofile/880/ ... 07.jpgThis was taken from this forum:
http://forums.genvibe.com/zerothread?id=4123
Re: Repositioned Passenger Wiper Arm Today (Sputnik)
Posted: Sat Jul 12, 2003 10:25 pm
by Vibe Rater
Just a quick warning: If you lift the hood to do this little job, be sure the wiper arm is in the down position before you lift it. If not you will scratch the hood. I'm good at this.
Posted: Sun Jul 13, 2003 6:34 am
Very. Deep...and long...As you can tell, I found that out too.
Posted: Sun Jul 13, 2003 10:04 am
by pwarren4
Did this to mine today - MUCH better!
Posted: Sun Jul 13, 2003 10:16 am
I HAD done this...but then I put it back. It doesn't bother me so much the wipers are visible when parked -- but when I adjusted it, the pattern didn't match up; the passenger blade at it's vertical point left a water mark about 3-4cm above the arc of the driver blade -- whereas in the factory location, it meets up just at the edge of the arc. Know what I mean?Anyway, that misalignment bothered me more, so I put it back.
Re: Repositioned Passenger Wiper Arm Today (ragingfish)
Posted: Sun Jul 13, 2003 11:41 am
by NovaResource
quote:but when I adjusted it, the pattern didn't match up; the passenger blade at it's vertical point left a water mark about 3-4cm above the arc of the driver blade -- whereas in the factory location, it meets up just at the edge of the arc. Know what I mean?I know exactly what you mean. That non-overlap creates a drip that always runs down the windshield. It only happens when it rains (obviously) and hasn't annoyed me enough yet to make me put it back.
Posted: Sun Jul 13, 2003 11:44 am
It wasn't even the drip so much, as the fact it didn't align. I'm (removed), and when things don't line up perfectly, it drives me NUTS!!!! Like my headlight isn't perfectly flush with the rest of the front end (casualty of the CAI install), and it's making me nuts -- I'm gonna make a dealer visit one of these days just to get that fixed. Argh.
