Someone cut away my driver side splash shield
Posted: Thu Feb 09, 2012 9:41 am
by SAMSAMSAM
Hello, I'm new.I went out to my car today (05 vibe gt) and noticed my front driver side wheel well plastic was hanging down. Upon closer inspection it looks like someone has cut away a portion of it and I'm not sure why. It might have ripped off while driving but the cut looks pretty clean for that. Does anyone know why someone might have done this? Is there an expensive part behind there or something? Any info would be helpful. Here are some pictures of it as well. http://imgur.com/a/rwSbVThanks,Sam
Re: Someone cut away my driver side splash shield (SAMSAMSAM)
Posted: Thu Feb 09, 2012 12:59 pm
by mac99d
That is crazy.......sorry to hear that.
Posted: Thu Feb 09, 2012 3:24 pm
by skimask
Looks more like a stress crack fracture to me. Probably got bumped/cracked sometime in the past and just kinda broke itself loose over time.
Posted: Thu Feb 09, 2012 8:14 pm
by djkeev
They're held in mostly with plastic clips. They work their way out or a mechanic damages them upon removal and doesn't install new ones and this is the result. Sadly, it happened while you were driving and you were blissfully unaware of it happening. Windows were shut, stereo on, motoring along, meanwhile, your car is shedding bits as you go along! That's the problem with modern cars, you're isolated from the mechanical as you drive.No problem, just order a new one and new clips, pop it in some weekend. You're only out $$'s. Take comfort in the fact that no one was messing with your car.Dave
Posted: Thu Feb 09, 2012 10:56 pm
by ligion
Mine broke off in the same place, and before i knew it, the tire wasw rubbing on it and most of it decentigraded and looked much of the same as yours. But it was pretty obvious that friction was the culprit on mine.
Posted: Fri Feb 10, 2012 9:13 am
by Blanco_Diablo
Weird about the splash shield, got nothing for you there... but welcome to the site!
