Roof starting to leak
Posted: Sat Jan 28, 2012 5:26 am
by CatharineSnyder
2003 Vibe. Roof has begun to leak just above the driver side where the cloth part of the roof and the top of the windshield support meet. Any ideas where I should do?
Posted: Sat Jan 28, 2012 6:18 am
by journeyforce
Is it have a sunroof? If so make sure the sunroof drain hoses are not blocked or disconnected.If not check the sear on the windshield as it maybe worn and allowing water in
Posted: Sun Jan 29, 2012 12:27 am
by MrsSlocum
My Vibe has done this!! Where the cloth meets the hard plastic around the door. It leaked good, like a slow steady drip.
Posted: Sun Jan 29, 2012 1:20 am
by CatharineSnyder
It does have a moonroof. I'll have to check the forum to see how to find the drains to see if they are clogged.MrsSlocum - what was wrong with yours and how did you get it fix?
Re: (CatharineSnyder)
Posted: Sun Jan 29, 2012 4:02 am
by djkeev
Quote, originally posted by CatharineSnyder »It does have a moonroof. I'll have to check the forum to see how to find the drains to see if they are clogged.MrsSlocum - what was wrong with yours and how did you get it fix?My 07 had a leak on the drivers side, turns out the drain holes in the front (there are also rear drain holes) were plugged with tree seed pods. Pulled them out and problem solved! Easy to see, just open the roof, stick your head out and look in the front corners, you'll see two holes towards the front of the opening.Dave
Re: (djkeev)
Posted: Sun Jan 29, 2012 12:26 pm
by MrsSlocum
^ Thanks for that! I'll have to take a peek at it tomorrow. Hopefully that's all it is!
