Stuck in recirc mode and blower fan only blows on high 03 vibe
Posted: Tue Jan 24, 2012 3:45 pm
by Canker
Just bought an 03 vibe today and this is my first post here.I'm guessing these two problems are unrelated and the fan is just the resistor pack but before I go buy a new one I wanted to ask. When I take it out of recirc mode I just get a clicking sound every 5 seconds or so until I put it back in recirc mode. I also don't get as much air out of the vents as I should. The only ones that really seem to work halfway decent are the dash vents. Before I go tearing things apart to find out what has jammed or come loose I thought I would ask if this is a common problem or not.
Re: Stuck in recirc mode and blower fan only blows on high 03 vibe (Canker)
Posted: Tue Jan 24, 2012 5:33 pm
by Canker
Posted: Tue Jan 24, 2012 9:18 pm
by sideshowalan
Be sure to read the whole thread.First post says to buy a new motor and remove the dash. Further down they explain how to do it without removing the dash, and without buying a new motor by just rotating the broken gear.
Re: Stuck in recirc mode and blower fan only blows on high 03 vibe (sideshowalan)
Posted: Wed Jan 25, 2012 1:00 am
by jake75
This broken gear seems to be the most frequent issue for the Vibe, and no doubt for the Matrix and Corolla. One would think that Toyota would have addressed this a long time ago but I suspect they are still using this badly designed part. Well, their dealer service department mechanics have to have something to do I guess. A few years ago on my '03 the cost with labor was about $80.
Posted: Wed Jan 25, 2012 1:50 pm
by Canker
I'm going to attempt going through the glove box and reusing the old part first. I really don't want to pull the whole dash out.Thanks
Posted: Sat Jan 28, 2012 5:18 am
by Canker
Fixed the recirc flapper motor and replaced the clogged cabin filter. That took care of the two of my problems. I also replaced the resistor pack but the blower fan still only works on high. Looking like the switch itself is bad.
Posted: Fri Feb 03, 2012 4:50 am
by Canker
Just in case anybody else runs into this problem.After replacing the resistor pack my fan still only worked on high. Busted out my multimeter and the switch and resistor both checked out fine. Before putting my fist through the window I decided to try using some electrical parts cleaner on the resistor pack's connector. Problem solved.
Posted: Fri Feb 03, 2012 7:31 am
by chadhgraves
Good deal. I always hate it when people fix a problem and don't follow up on how they did it. This forum isn't like that though. All the problems I've ran into so far, I've been able to fix by asking or searching through genvibe.
Posted: Mon May 27, 2013 6:27 pm
by earlyre
Canker wrote:Just in case anybody else runs into this problem.After replacing the resistor pack my fan still only worked on high. Busted out my multimeter and the switch and resistor both checked out fine. Before putting my fist through the window I decided to try using some electrical parts cleaner on the resistor pack's connector. Problem solved.
Seriously?? that simple?? clean the contacts?!?!
damnit!
my buddy's been dealing with that since he bought his '03 vibe in 2010!
