Sold my vibe, garage sale time
Posted: Sun Jan 22, 2012 11:14 am
by 4azdmunky
Well it was finally time. I traded in my 2005 1zz vibe, but before doing so I stripped off all the performance parts I could.So now its garage sale time, everything must go. Below are the asking prices minus shipping.Still for sale
  • 550CC Injectors (used for 3 days), 4 ea - $230
    1000CC Injectors (used for 30 min), 4 ea - $250 - Pending sale
    1zz power steering pump - $60
    Headlight dash switch assembly - $20
    Rear disk rotor and pads - $40
    PLX gauges – set - $700
    Boost/VacuumEGT
    Wideband O2
    Water Temp
    Oil Pressure
    Oil Temp
    2X Gauges and controller boxes
    Cosmo CAI with mount for meth spray injector(tube is scratched to hell but very functional) - SOLD
    1zz supercharger with Stock pulley, throttle body spacer, and belt. Only thing not included is the 180deg thermostat and the 2ea extended manifold studs. - SOLD
    TRD piggy back automatic- SOLD
    TRD supercharger air tube (if not sold with SC)- SOLD
    Greddy Emanage Ultimate and VManage (with 1zz adapter) with boomslang harness. - $700 - Sold
    2zz VManage dual adapter - $40 - Sold
    2.1 and 2.3 supercharger pulley (swappable hub, need to sell as set) - Sold
    Alutec crank pulley - $50 - SOLD
    DC Sports CS-2 strut tower bar - $130 - SOLD
    High output alternator - $80 - SOLD
    Snow meth injector pump+res. - $50 (SOLD)
PM or reply with questions/offersPaypal or cash (if in Denver and picking up locally)Been using "if it fits it ships" USPS for consistent and ease of shipping if cheaper, else UPS.
***All prices negotiable***
Thanks
Posted: Sun Jan 22, 2012 11:39 pm
by silverbullet
so how much meth did the super see? how many miles with and without it and how often did you spray?
Re: Sold my vibe, garage sale time (4azdmunky)
Posted: Sun Jan 22, 2012 11:59 pm
by BlueCrush
You have PM(s)!!!
Re: (silverbullet)
Posted: Mon Jan 23, 2012 9:22 am
by 4azdmunky
I tapped the windshield washer res and injected -20 or -32 windshield washer fluid. This royally F'd the SC up. I paid Magnason to rebuild the SC and set it up to work with water/meth injection. They recoated the blades and replaced all the bearings.I dont remember the injector size, It is the smaller of the Stage II MAF from Snow Performance. I injected around 4-4.5K on the tach, so only in openloop, and only when on it.As for MPG, it was weird. Some times I would get 33, other times I would get 23. Where i noticed the improvement was a WOT. A lot less detonation issues and it pulled stronger through the higher end of the power band.
Posted: Mon Jan 23, 2012 9:41 am
by silverbullet
So What did they change for it to work safely with the meth?
Posted: Mon Jan 23, 2012 12:35 pm
by danimal86
emailed
Re: (silverbullet)
Posted: Mon Jan 23, 2012 1:01 pm
by 4azdmunky
i sent it in for "warranty" work, since it started grinding. They called me back stating that the impeller coating was stripped off, and that that SC was not designed for water/meth injection and that using the water inject invalidated the warranty. I called BS, i was only running windshield washer fluid, there isnt anything in there to cause the coating to come off, and that Magnasun had this problem before on their Ford SC. They refused to warranty it. So it was somewhere around $680 which was bummer, i had only been running it for a little over a month and half at that time. They replaced the barrings with something of better quality and replaced or recoated the impellers (probably replaced)Now its rock solid, didnt have any more issues. Put around 40K miles on it since, at least another 40K more before the nose oil would need to be changed.
Posted: Tue Jan 24, 2012 6:05 am
by silverbullet
so the solution you were running contained no meth? so since the rebuild no more wear should be on the coating? so i guess that seems possible. it looks like thats the case if your saying you didnt change your set up with the spray after the rebuild, and you put that many more miles on it w/o problems.trd supercharger air tube? is that for using with the stock air box??
Re: (silverbullet)
Posted: Tue Jan 24, 2012 10:28 am
by 4azdmunky
Magnuson was saying it was the velocity of the water drops that "sand blasted" the coating...yeahWindshield washer fluid contains methanol, just not as good a boost juice, more watered down. It provided the cooling effects of water, with just a touch of meth. Would have loved to have tried it with boost juice.Yes, the airtube is for stock airbox.
Posted: Tue Jan 24, 2012 12:52 pm
by silverbullet
To state the obvious I'm interested in the charger, just worried about the coating since it was sprayed. I'm not sure what to make of it. It went bad in the first few months and ever since the repair its lasted as long as you say with no problems. Maybe the problem was not the spray in the first time? Just a fluke thing. Of course they won't cover if they can easily blame it on meth. I'm sure you won't have trouble selling this, just may take some time. If you still have it in a short time I just may scoop it up. Having a hard time justifying spending that much cash right now.
Re: (silverbullet)
Posted: Wed Jan 25, 2012 4:14 am
by 4azdmunky
Totally understandBTW, updated first post to include statement that all prices are negotiable...odd thought I had that in the origional post..oops
Posted: Wed Jan 25, 2012 4:33 am
by Salsa Guy
Does the price on the TRD ECU include the TRD Adapter and Harness? Also which TRD ECU do you have M/T or A/T?
Re: (silverbullet)
Posted: Wed Jan 25, 2012 10:03 pm
by 4azdmunky
Re: (Salsa Guy)
Posted: Wed Jan 25, 2012 10:09 pm
by 4azdmunky
The TRD ECU is for automatic, thanks for point that put, I'll add it to the post.it does include the adapter, and harness, however i had wired the harness up to a boomslang because the adapter does not work with 2005 DBW.
Posted: Wed Jan 25, 2012 10:59 pm
by Salsa Guy
Not really understanding what you did to the TRD adapter and harness. The adapter fits in to the stock ECU. Then there's a harness that plugs into the adapter and into the TRD ECU. Did you modified the adapter or the harness? You must have some good skills to modify the TRD adapter to fit the EMU. Because the TRD ECU doesn't directly mess with the injectors. It basically lies to the stock ECU via the MAF and O2 for the desired results
Posted: Wed Jan 25, 2012 11:18 pm
by silverbullet
I'm thinking he used the trd on its own. Used the harness to be able to wire it into the car. I don't think he means he used the trd and the emu simultaneously.
Posted: Wed Jan 25, 2012 11:32 pm
by Salsa Guy
I wouldn't think so but using the TRD Adapter and Harness for the EMU would require some pretty good soldering skills. Including cutting traces on the adapter and adding wires. I'm sure it could be done but not for a novice.
Posted: Thu Jan 26, 2012 5:05 am
by Salsa Guy
PM Sent
Re: (Salsa Guy)
Posted: Thu Jan 26, 2012 12:20 pm
by 4azdmunky
SO for the TRD ECUThe pins changed between 2004 and 2005. All I did was cut off the end of the factory harness, and wire it accordingly to the 2005 pinout, using an old Boomslang i had sitting around.
Posted: Fri Jan 27, 2012 12:08 pm
by silverbullet
do you have the fifth injector? is it just another of the stock size or different? not sure what wiring would be needed for that also. thinking if i get my taxes filed and we can get a deal on the super and trd ecu shipped that money could be headed your way in a couple weeks. dont you need an idler pulley also? or mounting bracket of something? if i get the super and the trd computer what else would i need? colder plugs and thermostat? studs you mentioned also, sure i can find them at the hardware. i would rather run the system on emu and larger injectors but i would be happy just to get it operational at as low cost as possible. can always upgrade later. o also i have aftermarket air intake. how hard is it to get hooked up to that? is there really any difference?i am 03 will the trd ecu work for me?on a sidenote, my girlfriend is going to hate me for this.
Posted: Fri Jan 27, 2012 1:01 pm
by silverbullet
also what size pulley were you running full time, how much boost did you gain?
Re: Sold my vibe, garage sale time (silverbullet)
Posted: Fri Jan 27, 2012 1:23 pm
by 4azdmunky
The 5th injector is mounted on the bottom by the throttlebody. Im not sure what the size. If you go with a 550 CC injectors you dont need to even wire up the 5th injector.I had the 2.1 pulley on it and with the emanage+water injection I was able to peak out at a little over 10lbs of boost. I put the stock pulley back on the SC because any size smaller then a 2.3 pulley and the SC starts heating up. The water injector helped by cooling the air charge, so heat was never an issue. I think thats why I was able to get 10lbs reliably with the smaller pulley where others had problems.So unless someone is going to snag up the SC and the meth injection kit and the pulleys, it made sense to put stock pulley back on.Oh yes, the idler pulley is included with the SC. Remove top bolt from alternator, loosen bottom bolt, swing alternator out. Bolt the idler puller with bracket to where the top bolt of alternator was, bolt alternator to idler pulley bracket, tighten everything up.
Posted: Fri Jan 27, 2012 1:32 pm
by 4azdmunky
I ran with a COSMO CAI no problem. I picked up a 45 degree elbow from these guys:http://www.siliconeintakes.comthey are cheap in cost and fast in shippingtotally understand the GF I picked up a 2009 Dodge Ram 1500, 5.7 MDS, Laramie , 24 hrs later I had a CAI on the way....wife is pissed...oh well, good thing i sleep great on the couch, so do what you feel you need to do.
Posted: Sat Jan 28, 2012 6:00 am
by silverbullet
Yea but can I run thebigger injectors without the emanage? I don't plan on spending the extra on engine management right now.
Posted: Sat Jan 28, 2012 7:43 am
by Salsa Guy
Yes! The ECU will figure it out. Now it may run rich for a while until it does. The TRD 5th injector is 660 cc/min I think. The TRD ECU will work with your 03.
Posted: Sat Jan 28, 2012 10:44 am
by silverbullet
yes the ecu will figure it out? do you mean the ecu will correct to a safe af and be ok. or correct to spray the stock amount of fuel and run me too lean for the supercharger? sorry munky for the thread jack. i actually have the money for this if i figure out if i can make it work without a TON of extra parts/money.
Re: (silverbullet)
Posted: Sat Jan 28, 2012 11:39 am
by 4azdmunky
naw bro roll with it, if it helps others and get this stuff sold, i dont care.
Posted: Sun Jan 29, 2012 7:21 am
by Salsa Guy
The TRD ECU is a piggyback and it will correct the fuel for the SC. If you just toss in the bigger injectors with the SC without the TRD ECU (or any piggyback) you'll run lean for a boosted engine. If you get a Greddy EMU or AEM FIC it will need to be tuned.
Posted: Sun Jan 29, 2012 8:33 am
by silverbullet
pm!!
Posted: Mon Mar 05, 2012 7:36 am
by Jroberts238
Still have the CAI? Also be interested in the Snow meth pump and res
Re: Sold my vibe, garage sale time (Jroberts238)
Posted: Mon Mar 05, 2012 3:01 pm
by 4azdmunky
I do still have the COSMO CAII used the meth injector to spray windshield washer fluid before the supercharger to cool the air charge. This allowed me to safely run 2.1 pulley and mitigate the heat.The snow pump was ran from the EMU that I recently sold. The snow MAF controller box no longer worked. I had it running off of the output wire and varied the voltage by RPM and only sprayed when in the upper band.
Posted: Wed Mar 07, 2012 10:25 am
by Jroberts238
Ah I see I was thinking it was something else. I am interestd in the CAI. How much shipped to 37311?
Posted: Fri Mar 09, 2012 3:42 pm
by Jroberts238
If you can get me a price i will buy it.
Posted: Sun Mar 11, 2012 12:39 pm
by 4azdmunky
Its a little over 35$ to ship it, so $75 total for the CAI, the dry filter, shipped. The tube is tapped with the meth injector, so this includes the injector. Is that still okay?
Posted: Sun Mar 11, 2012 8:22 pm
by Jroberts238
Any ill effects of having it on there without actually using it?
Posted: Mon Mar 12, 2012 12:37 pm
by 4azdmunky
i could pull the sprayer and put a plug in its place. I doubt the air pressure would be enough to cause the injector to leak, but wouldnt want to put anyone in a predicament where it was. Standby, illl see if I can set it up so it wont be an issue at all.
Posted: Wed Mar 14, 2012 8:55 am
by Jroberts238
Ok just let me know, I hope there's a way to seal it up pretty decent deal.
Posted: Tue Mar 27, 2012 5:24 am
by 4azdmunky
K, cleaned up, PM sent
Posted: Wed Mar 28, 2012 12:12 pm
by 4azdmunky
