driver door interior panel access?
Posted: Wed Jan 11, 2012 12:32 pm
by miksis
My window and lock controls have disconnected from my surface controls. How can I access the interior to hopefully reconnect?
Re: driver door interior panel access? (miksis)
Posted: Wed Jan 11, 2012 1:06 pm
by ParknVibe
Quote, originally posted by miksis »My window and lock controls have disconnected from my surface controls. How can I access the interior to hopefully reconnect?I am having a hard time believing that the controls "disconnected" from the wiring plugs behind them.You have to give the forum what year the Vibe is. A 2009 model has three screws to remove before you can remove the door panel. The earlier vibes have two screws. One screw is behind the cover of the door opener handle. I can't remember where the others are.
Re: driver door interior panel access? (ParknVibe)
Posted: Wed Jan 11, 2012 9:23 pm
by DeClerq
Quote, originally posted by ParknVibe »One screw is behind the cover of the door opener handle. I can't remember where the others are. The second one (on earlier Vibes) is at the bottom of the door pull. You'll also want to remove the little triangular trim piece up by the mirror. It just pulls out.
Posted: Wed Jan 11, 2012 11:39 pm
welcome to genvibeOne thread about how to remove the door panels is
http://forums.genvibe.com/zerothread?id=24086Some people have had a problem where the driver's window/lock switch assembly has detatched from the silver trim piece and sunk into the door. from the slightly different desciption you posted in
http://forums.genvibe.com/zerothread?id=46021 it sounds like that is the problem, and if so, then perhaps
http://forums.genvibe.com/zerothread?id=45097 will be pertinent.
