Squeaking noise when rocked
Posted: Tue Jan 10, 2012 11:39 pm
by bull77
see video:
http://youtu.be/12QVWcDmuXUIs this a engine mount or another mount that is worn? Should I be concerned and get this fixed asap?
Posted: Thu Jan 12, 2012 12:55 am
by bull77
35 views and no comments? Has no one seen or heard this before on a Vibe or any other car?I can't be that special
Re: Squeaking noise when rocked (bull77)
Posted: Thu Jan 12, 2012 1:46 am
by micbarric
Mine makes that noise also. It only happens after the car has been driven, and goes away after it cools off.It has done it for years and the noise hasn't gotten any worse, so it's probably nothing serious (I hope).
Posted: Thu Jan 12, 2012 2:02 am
by bull77
same here -- its been over a year since it started, seems to happen more when it's damp out. Just curious since I also developed a thunk on the front passenger side when driving over bumps/turning. I have new Tokico struts already bought to replace my original struts -- just waiting for the snow to melt
Re: (bull77)
Posted: Thu Jan 12, 2012 3:28 am
by djkeev
Thump could be.... ball joint, tire rod end, worn control arm bushings, worn sway bar mounts, worn shock or upper strut bearing assembly.I didn't listen to your squeal though.Dave
Re: (djkeev)
Posted: Sat Jan 14, 2012 12:29 pm
by cq358
bushing noise.Spray each bushing with Silicone /wd40 Start with control arm bushing and then to your stabilizer bar bushingsand tell us the finding.
Re: (cq358)
Posted: Sat Jan 14, 2012 1:41 pm
by cq358
Re: (cq358)
Posted: Wed Jan 18, 2012 3:28 am
by sideshowalan
Agreed on the bushings, most likely front sway bar. Hit them with a silicone spray, move the bar back and forth a little bit if possible to spread it around. The end links also each have 2 bushings on them, check these for obvious rips or damage.They're inexpensive/easy to replace too. Control arm bushings not so much.
