5 Speed Transmission Problems and Replacement
Posted: Fri Jan 06, 2012 4:30 am
by cthomasparr
Hi,Was looking at buying a 2004 vibe with a bad 5 speed transmission. After some research was surprised to learn there are problems with these transmissions leading to somewhat early failures. Does anyone know if these problems were eventually corrected after 2004?Also, if I was in the market for a replacement, is there a direct replacement available that is also reliable. putting in a lower mileage overpriced suspect trans is not a good option.For replacing a 5 speed, I have read the vibe GT 6 fits in without any alteration, but results in a higher engine speeds on the highway. The local junk yard told me corollas from 2004-2006 are same as 5 speed Vibe in 2004. Does anyone know of a resource that shows the compatability?Thanks
Re: 5 Speed Transmission Problems and Replacement (cthomasparr)
Posted: Fri Jan 06, 2012 4:37 am
by trb
http://www.car-part.com agrees that some Corolla and Matrix transmissions are a direct exchange. They use the Hollander Interchange manuals for parts compatability. I just ran a query for 2004 Vibe with 5 sp manual and got lots of salvage yards nationwide with Vibe, Matrix and Corolla (not FX), transmissions from 2003 through 2008 that should fit.
2004 Matrix 5-speed transmission failure: Vibe also??
Posted: Tue Jun 26, 2012 2:34 pm
by unbearable
Hello everyone. It is my understanding that the Toyota Matrix and Pontiac Vibe have the same transmission and engine. Please be aware of a serious transmission problem on these vehicles.
It seems that many Matrix owners are having problems with a faulty transmission bearing which necessitates the transmission needing to be replaced prematurely. I would think this applies to Vibe owners also. We had to replace our five-speed manual transmission on our 2004 Toyota Matrix at 98,000 miles at a cost of $3,100! Models besides the 2004 are also affected, but I don't know which ones. I sent a certified letter to the president of Toyota Motor Corp. North America. I was told since there is no recall, I would not be compensated.
It is important to notify Matrix and Vibe owners about this problem before their life is endangered when the car breaks down without warning on a 70 mile-per-hour highway. This is what happened to me. There are numerous reports of Toyota Matrix 5-speed transmission failures due to a defective transmission bearing. I don't believe a manual transmission should need to be replaced at 98,000 miles. Some vehicle owners have had it happen at less mileage. The regional manager of the repair shop I took it to said he has seen this problem before, and he believes there will be a recall. At this time, Toyota will not compensate Matrix owners for this very expensive defect.
Please sign my petition at http://www.change.org/petitions/unbeara ... on-bearing" onclick="window.open(this.href);return false; Hopefully if there are enough signatures, Toyota will do a recall .
Thank you!!
Posted: Wed Jun 27, 2012 4:40 am
cthomasparr wrote:. After some research was surprised to learn there are problems with these transmissions leading to somewhat early failures.
A number of us here were surprised when our 5-speeds failed. Toyota really played up their bullet proof reliability, and the fact that car was mostly Toyota was considered a significant advantage for a number of Vibe buyers. It has since really soured my opinion of Toyota. I was no fan boy before, but now I find myself quite anti-Toyota
There are some high mileage 5 speed Vibes with no tranny troubles. I suspect that in addition to the weak bearing issue, there is some driving style that somehow accelerates the weak bearing failure that unfortunately seems to be my driving style, but that's only conjecture.
Unfortunately, my advice would be to pass on the 5 speed, and instead find an automatic tranny Vibe. Manuals are more fun to drive (imho) but the auto tranny used in Vibes has been quite reliable, and the power/acceleration differences between auto and manual tranny vibes is token. Because of the different gear ratios, the 6 speed should be less efficient than the 5 speed, but I don[t remember seeing any documented numbers, especially ones that eliminate the unintended change to driving habits.
However, if the price on the bad tranny Vibe is too attractive to pass up, then try to find a replacement from the latest compatible model possible, even for a higher cost. I do trust the car-part.com site trb posted to provide accurate parts compatibility info.
unbearable, I am not sure the tranny reliability issue is really a recall worthy problem. Good luck to you on the recall petition, but I wouldn't be too optimistic.
Posted: Thu Jul 05, 2012 12:32 pm
by circuitsmith
I suspect some of those early failures are due to the fact that (at least with my 2006 Matrix) Toyota doesn't recommend changing the trans oil except when towing.
I've owned 3 5-speed Hondas and they all called for changing the trans oil every 30k miles.
I changed the oil in my Matrix early at 21k miles and it was dark with a metallic sheen and a slightly gritty feel.
Looked worse than the Hondas ever did at 30k.
I'd hate to see what what it would have been like at 90k miles.
I plan to change it again after another 20k. If it looks good I'll stretch the interval to 30k.
Posted: Tue Dec 19, 2017 6:14 pm
by GTwannabe
circuitsmith wrote:I suspect some of those early failures are due to the fact that (at least with my 2006 Matrix) Toyota doesn't recommend changing the trans oil except when towing.
I've always changed my fluid every 30k miles and the transmission suddenly failed at 160k miles.
Posted: Sat Apr 06, 2019 4:02 am
by lm7212
Add me to the list, found a nice low mile stored inside '04 Toyota Matrix with 73k miles from an estate, an older gentleman owned it. At 81k 5th gear failed on the freeway at 73mph. Pulled over and called my mechanic friend, he said keep it in 1st 3rd and 4th to get it somewhere I could work on it. Towing company quoted me $450 to get it to the next major city 40 miles away. Made it to my cabin going 52mph, with my handicapped son and our dog in the car. I kept looking for occupied houses we could walk to if the thing decided to sieze up on us, as it was 12 degrees that day.
Found an '06 vibe at a bone yard near me, replaced trans and clutch assembly and the works, took a buddy and me 2 days and a lot of up down up down. Car made it a quarter mile and that tranny failed too. That one did lock up trying to limp it back to our shop. I gently placed it in reverse and back into first and it let the car move, thankfully.
Had it towed to a transmission shop. They frankensteined the 2 transmissions and installed a complete bearing set for $2640.
Anybody want to buy a low mile Matrix? I can hardly stand to look at the thing. I had a '05 Corolla and a Vibe I put well over 240k miles on both and sold them running just fine. DO YOURSELF A FAVOR AND STEER CLEAR OF 03-05 TOYOTA MATRIX 5 SPEEDS! This car literally put our lives at risk several times in it's failures. Shame on you Toyota bean counters who decided to use substandard materials in your bearings to save a few bucks.
Posted: Sat Apr 06, 2019 9:43 am
by SeattleJeremy
lm7212 wrote: ↑Sat Apr 06, 2019 4:02 amShame on you Toyota bean counters who decided to use substandard materials in your bearings to save a few bucks.
I agree that people should be aware of the 03-05 5-speed issues, but from what I remember it wasn't the bean counters fault this time. The Toyota C59 transmission works fine in the 2500lbs 1998 corolla (for which it was designed for), but it wasn't up to the task of the heavier and taller 2700lbs Vibe/Matrix.
Posted: Mon Apr 08, 2019 10:48 am
by zbyers
SeattleJeremy wrote: ↑Sat Apr 06, 2019 9:43 am
Absolutely agree. Had nothing to do with cost cutting.
Posted: Thu Dec 26, 2019 8:05 am
by randomguyother
2006 Vibe that just grenaded the c59 transmission. Bearing at shaft disintegrated and caused all sorts of gear chipping/debris. Just tore it down and replaced all bad parts and installed a rebuild kit. Works fine now. Essential info below.
I worked through toyota for all of my parts and dealer info.
- my main sources:
- general transmission removal: https://www.toyotanation.com/threads/di ... cs.959473/
- general c59 disassembly: http://www.tcorolla.net/overhaul-1203.html
- c59 differential ring removal and install: http://www.tcorolla.net/overhaul-1212.html
- output and input shaft gear pulling and pressing: various youtube videos.
- main culprit: The bearing that looked worst had the following identification on the inner race ("HTF...B25-163Ag") and outer race ("NSK...JAPAN...630Z"). Note that the replacement bearing that came in the rebuild kit was identical. I opted to use a different bearing (totally sealed on both sides, unlike the original) from toyota. I just let the parts department identify the superseding part.
- "Rebuild Kit": Note that there are two very similar kits out on the market. Go to "www.transmissionpartsdistributors.com" and see the difference between their "BK418BWS" and "AWS" kit. A difference of 0.020". Easy to mix up and not everyone offers both kits to choose from. The "BWS" worked for my vibe.
- Advice: Go to friendly dealer. Give them car info. Have them print out all schematics of: internal shafts and gears, differential and bearings, overall trans case. During tear down, identify all parts to replace. Have them identify all toyota part numbers (the numbers in the schematics are the short 6 digit codes that aren't specific enough). Use the real toyota part numbers to buy for 60% the cost using an online toyota parts dealer.
- Advice: Be organized during tear down. Take photos. Ensure all parts are removed and laid down so you know the orientation/order. label all parts against the step number for reference.
- Minimal tools: Press. Various pipes (measure the exact sizes you need to press bearings and gears and order from mcmaster carr. Cut to 6" or 12" lengths.). Inside diameter blind pullers (expand to allow hammer pulling from one side). Outside diameter bearing pullers (various sizes). Bench grinder (you'll need to grind your pullers to fix exactly and be prepared to get replacement pullers). Impact gun to make pullers work better. Clamps to hold pullers in place while using impact gun. Small plate with and without holes to protect pointed tips of pullers when pulling on shaft without a hole.
- Advice: On the differential, I just approximated bearing preload by spinning the differential teeth with a long screwdriver. Did not use a tool in the middle hole.
- Advice: Note that not all bearings are pressed and bottomed out. Read the instructions from toyota above at each step.
- Advice: When the two case halves are sealed and bolted together - you will probably fail to get the two shafts to stick out far enough for the snap rings to be installed. Don't panic. Tap (with wood block) on the input shaft in the bellhousing from below while pulling up on both shafts to get them moved up a little. You don't need to tear it all apart and repress bearings.
- It won't be clear exactly what parts the rebuild kit comes with compared to your toyota part numbers. Plan on sucking up a restocking fee from someone. If you're getting close to a 30-day return window - contact the distributor and get an allowance of time in writing.
- Advice: If you're hammering when you should be pressing during reassembly, you're doing something wrong. Make sure it all gets seated correctly and straight.
My rebuild cost ~$1,300 on trans internals (new shaft, diff ring gear, some gears, and rebuild kit). ~$350 on new clutch and rear main seal.
have fun. don't rush. if something seems too tough - walk away and think on it.
Posted: Fri Feb 14, 2020 8:03 am
by Fugue
Hi all,
I wanted to say thanks to everyone for the info/posts-they helped me greatly!
I have a 2005 Pontiac Vibe 5 speed (Toyota C59 tranny). I count myself lucky in that the rear output shaft bearing issue only surfaced after 230,000km! My Vibe is the family pickup truck-I have hauled trailers with it, loaded it to the gunnels many times, and it has been as reliable as an anvil.
I replaced the gear oil at 160000km (in 2015) at the same I replaced the clutch and flywheel. On the advice of online forums I used Blumenthal NV4500 oil (repackaged Castrol Syntorq 75W-90 GL4 synthetic oil which I am told is no longer made)-it was listed as the equivalent to the GM-recommended oil for the car. Replaced the oil with the same stuff 50,000km later. The noise started towards the end of a 2000km IKEA run hauling a new kitchen divided between the car and a 5x8 UHaul trailer.
GM doesn't list the replacement parts anymore-no surprise there. I decided to go with replacing all the parts exposed when the rear housing was removed with the transmission still in the car (yay!) - it was smart to do everything while it was apart. Had a local tranny shop do the work (3 hours shop time). I live in Northern Ontario-the winters are brutal up here, so the cold deterred me from my own garage this time. On the advice of Monkey Wrench Racing, I refilled with Valvoline MTF oil. Smooth as silk!
The slop in the old output shaft bearing was alarming-I think I got to the repair just in time. Absolutely no wear to the input shaft bearing or the 5th gear needle bearing. The replacement output shaft bearing was a new design-it is a sealed NSK 25TM21 unit-the original was an open NSK 6305Z. It obviously wasn't getting enough of an oil bath-we'll see how much better the sealed unit works.
People have mentioned the extra weight of the Vibe as a contributing factor in the premature wear. In my case, with all the heavy loads and trailer hauling for all that mileage leads me to believe that the oil I used made a huge difference. We'll see how well the Valvoline stands up.
Again, my thanks!
Fugue
Posted: Fri Feb 14, 2020 8:56 am
by zbyers
Fugue wrote: ↑Fri Feb 14, 2020 8:03 am Hi all,
Again, my thanks!
Fugue
glad to hear you were able to rehab your trans to extend the life! Feel free to start a thread with pics of your ride, and include some pics of the things you've towed. I love to see these in action.
Posted: Sat Feb 15, 2020 5:16 pm
Welcome to GenVibe Fugue ;) We love hearing success stories like that. Post pics and more info soon. Just curious how your Vibe is holding up due to rust/corrosion? Do you apply any Krown or Rust Check annually? That seems to be really big up there in Canada.
