About to sound deaden doors....quick question
Posted: Fri Jan 06, 2012 12:54 am
by cptnsolo77
I purchased this sound deadening material here:
http://www.soundproofcow.com/s....htmlDo I junk the moisture barrier? or do apply the the deadening material & reinstall the moisture barrier over it?
Re: About to sound deaden doors....quick question (cptnsolo77)
Posted: Fri Jan 06, 2012 1:22 am
by trb
Are you putting it inside the door, or on the door in between the door and door panel, like how the moisture barrier is installed? I've always thought the sound insulation went inside the door, not on it?
Re: About to sound deaden doors....quick question (trb)
Posted: Fri Jan 06, 2012 1:28 am
by Serj22
Putting it inside the door would mean you would ahve to use strips and it amy interfere with the window, which is innefective and a waste. Classically it is put on the side where the moisture barrier is "glued" down. I usually remove it because it will cause the sound deadener to "float" off the door and thats not what you want.
Posted: Fri Jan 06, 2012 2:06 am
by cptnsolo77
Yes. I am putting on the side where the moisture barrier is glued on. So I just chuck the moisture barrier? Will it cause any "moisture" problems? LOL. Thx for the quick reply guys!
Posted: Fri Jan 06, 2012 2:32 am
by ParknVibe
Quote, originally posted by cptnsolo77 »I purchased this sound deadening material here:
http://www.soundproofcow.com/s....htmlDo I junk the moisture barrier? or do apply the the deadening material & reinstall the moisture barrier over it?From what you show in the picture, That looks like the dynamax type sound-deadening that is to be applied to back side of the door's sheetmetal to suppress the tingging sound of the paper thin metal.
Posted: Fri Jan 06, 2012 3:54 am
by cptnsolo77
Ok....just got done with the right rear side. That speaker was starting to buzz so I did that one first. Sounds amazing even with the stock M&T HU. I did a before & after listening test. I noticed that I DID lose some bass with the Polk speaker vs. the stock speaker. However AFTER I was done with the sound dampening I listened again. I regained the bass I had lost without the dampening. Im happy. The POLK DB series have some great imaging. The highs can be really sharp but I just turned down the treble. Just need to set another day for the rear left. Im in no rush since that one isnt blown. Thank s Gen Vibe....
Posted: Fri Jan 06, 2012 4:24 am
by KNINE
http://www.soundproofcow.com/s....htmlDo I junk the moisture barrier? or do apply the the deadening material & reinstall the moisture barrier over it?That's where I got mine from. I junked the moisture barrier and put mine on the door under the door panel. I hed some scraps left over that I put between the inner and outer door metal directly behind the speaker.
Posted: Fri Jan 06, 2012 4:35 am
by cptnsolo77
Hmmm....maybe I should hold onto the moisture barrier? I just threw it into the trash. Will it be a problem if i dont use it? I dont feel like taking the door panel off again LOL. Maybe it was you, K9 that posted soundproofcow.com. It was great ! 37 bucks & enough for both rear doors ! I sat in the car again & noticed the bass is equal to the stock speaker but much tighter. When these speakers break in it will sound pretty darn good for a car without a sub.
Re: (cptnsolo77)
Posted: Fri Jan 06, 2012 10:52 am
by Blanco_Diablo
I peaced-out the moisture barrier. You won't need it. Deadened that surface as well as the inner surface of that same panel. Lowered noise a touch and definitely helped the speakers. Haven't had any issues.
