Fuel Gauge Stuck
Posted: Wed Dec 28, 2011 11:29 am
by MisterHighway
Hey Viberators,I'm coming up on 210k on my 2003 base vibe, I filled up my tank yesterday and since then my fuel gauge has been stuck on full. It drops back to home position when I turn it off, and goes back to the full mark. It is decently cold out (about 25-35F) and the vehicle has been driven and warmed up. I'm not sure if it is the gauge is bad or not. I've never had any issues with it before this. I did fill about a $1.20 over where it "stopped" automatically at the pump, (which is about a 1/3 of a gallon). It seems like it has gone down maybe a hair, but it went back to the position it was before. I would appreciate any thoughts or ideas, like parking it in a warm area or tapping the fuel tank or something.Thanks ahead of time,-[MisterHighway]
Re: Fuel Gauge Stuck (MisterHighway)
Posted: Wed Dec 28, 2011 12:12 pm
by zoomie
"Techron® Concentrate Plus delivers a number of unsurpassed benefits and one unique benefit - the ability to help eliminate faulty fuel gauge readings."
http://www.chevron.com/product....aspx
Posted: Wed Dec 28, 2011 9:02 pm
by keithvibe
You didnt mention if this was an on going issue or something that happened with this tank only?You also didnt mention how many miles you have driven on this tank?I'll drive 60-100miles before the gauge moves off full.
Re: Fuel Gauge Stuck (keithvibe)
Posted: Thu Dec 29, 2011 1:32 am
by star_deceiver
Quote, originally posted by keithvibe »I'll drive 60-100miles before the gauge moves off full. Yup, the needle doesn't move for me until I've driven about 100kms in the winter or 140 in the summer.
Posted: Thu Dec 29, 2011 1:45 am
by jake75
Quote, originally posted by MisterHighway »Hey Viberators,I did fill about a $1.20 over where it "stopped" automatically at the pump, (which is about a 1/3 of a gallon). It seems like it has gone down maybe a hair, but it went back to the position it was before. I would appreciate any thoughts or ideas, like parking it in a warm area or tapping the fuel tank or something.Thanks ahead of time,-[MisterHighway]The only thought I have is "stop overfilling the gas tank". While I doubt that would cause the fuel gauge to stick, it can lead to expensive damage to the fuel tank emission control system. I see people at the local supermarket station doing that because they are getting perhaps $1 off each gallon in rewards. That extra 40 cents you save can get costly. Many also fill 5 gallon cans - IMO the danger of transporting gasoline in that manner isn't worth the money saved. When my old gasoline mower bit the dust I got a Black & Decker battery powered one in part to eliminate handling/storing even a 2 gal container of gasoline.
Posted: Thu Dec 29, 2011 2:13 am
by Old Tele man
...although it does NOT "stuff" as much gasoline into the gas tank, simply use the ONE-CLICK method when re-filling the tank...each and every time!
Re: (Old Tele man)
Posted: Thu Dec 29, 2011 3:22 am
by keithvibe
Quote, originally posted by Old Tele man »...although it does NOT "stuff" as much gasoline into the gas tank, simply use the ONE-CLICK method when re-filling the tank...each and every time!^^^thisRun the pump as slow as you can and you will get the fullest tank you can when it clicks off. Fill it at the max setting you will end up having less fuel in he tank. If people weren't in such a hurry and filled the gas tank slower they wouldn't have to keep clicking every last drop in to the tank and ultimately into their evap system.
