				2009 Camry 17 inch alloys on my 09 2.4 Vibe
				Posted: Fri Dec 09, 2011 12:45 am
				by NWEric
				This weekend, I'm looking at buying some 17 inch 09 Toyota Camry alloys for summer tires. I've got the 205/55 16 winter tires on my steel rims. I know the 09 Camry bolt pattern is correct for the 2.4. I would run 215/45 17 tires, the standard size for the Vibe/Matrix 17 inch rims. I'd love some feedback from those of you with the larger tire on your Vibe. How stiff is the ride? I have 45 series tires on my Miata so I'm used to a sporty ride. However, I'd be be doing some gravel road travel and am concerned about that short a sidewall. Any opinions would be appreciated. Should I wait for some 16 inch alloys or go for the 17 inch?
				Re: 2009 Camry 17 inch alloys on my 09 2.4 Vibe (NWEric)
				Posted: Fri Dec 09, 2011 1:49 am
				by 09vGT
				I've got a GT so I've got the 18's. Its a VERY stiff ride. There is definitely no gliding into bumps.
				Re: 2009 Camry 17 inch alloys on my 09 2.4 Vibe (09vGT)
				Posted: Sat Dec 10, 2011 1:34 am
				by vibenvy
				I too have an 09 GT with the OEM 18s and the ride is stiff and sporty which I personally like.I say go for it as long as the offset is the same as the Vibe, they should fit fine.
				Posted: Sat Dec 10, 2011 2:14 am
				by Kincaid
				I have 215/45-17's on mine and do not find the ride to be too "stiff" or harsh.  If you have no issues in the Miata I'm sure you'd be fine.Gravel should be no problem - it's the potholes you got to watch out for!
				Posted: Sat Dec 10, 2011 2:56 am
				by star_deceiver
				Do it!!!
				Posted: Sat Dec 10, 2011 3:26 am
				by cq358
				I remember the offset for 17" Camry rim is 45mm.. you might need to go to yotanation and check out their camry forum
				Posted: Mon Dec 12, 2011 4:50 am
				by NWEric
				I decided to pass on the 17 inch wheels. Not sure I want to go lower profile. You are right about the 45mm offset for Camry wheels. A lot of the Toyota/Scion wheels are 45mm. What I'd really like to find is some 16 inch Matrix alloys.
