Defective wheel bearing?
Posted: Sun Nov 20, 2011 11:11 pm
by CRS
Had the right front wheel bearing on my 2004 Vibe replaced about 2 months ago due to humming noise - noise went away. About 1 month goes by and the noise returned. Took it back to the shop and they said it must have been a defective bearing. I've never heard of a defective bearing but they replaced it for free so okay with me - noise went away again. Now another month has passed and the noise is back. Could something else be causing the bearing to go out that quickly?
Posted: Sun Dec 11, 2011 4:32 pm
by DraziWDragon
check lower A arm/lower control arm.also check the tie rods, ball joint, cv axles shafts and joints, camber bolts, steering alignment. and upper control arm.
Re: Defective wheel bearing?
Posted: Thu May 17, 2012 7:23 pm
by DraziWDragon
an update. My wheel bearings are making noise now. sounded like it was REALLY bad on the drivers side. had it replaced.
Still sounds noisy as all heck, and from the drivers side. Until i sat around in the car while someone else was driving. ITS the friggin passenger all along. i think its because of the long axle shaft. it causes the noise to sound like its coming from the left side. SO, replace both at the same time, and you will know which it is.
The bearings pretty much fell apart when trying to separate them from the hub.
Posted: Thu May 17, 2012 7:29 pm
by KITT222
I need to replace mine, and I am very confident that it is the drivers front. I even jacked the car up and spun the wheel and it gave the same noise it did while driving.
Posted: Thu May 17, 2012 7:33 pm
by DraziWDragon
ebay has timkin replacement bearsing for around $30. i got both of mine for $50 total. free shipping.
Posted: Mon Mar 18, 2013 9:01 am
by CRS
How hard is it to replace the front hub & bearing assembly?
Posted: Mon Mar 25, 2013 5:11 am
by clownshoes
I had my front one done over a year ago, and now another one is making noise. Hopefully it;s the same one and it'll be covered.
'05 Vibe btw....and AWD.
Posted: Mon Mar 25, 2013 3:01 pm
by 09SnowyVibe
Make sure the shop uses a PRESS to install the bearings, NOT HAMMERS. When the hub is pressed in, make sure the center race is supported properly, or you will junk the bearing.
Posted: Tue Mar 26, 2013 10:45 am
by clownshoes
Yup. I go to a respectable shop and they warranty what they sell/repair. As it turns out one of my old friends works there now and he's a really good mechanic.
