Replacing temp control dash light.
Posted: Fri Nov 11, 2011 12:10 am
by MSAGRO
How do I get behind to replace? I did the search, but no luckStep by step will help as will a link and access to get replacement bulb.
Posted: Fri Nov 11, 2011 2:54 am
by 455SD
Thread is here. Try to to when Vibe is warm on the inside. The plastic tabs/fingers that attach the control to dash are brittle, and the cold makes them more so.
http://forums.genvibe.com/zerothread?id=17244
Re: (455SD)
Posted: Fri Nov 11, 2011 5:39 am
by MSAGRO
Thanks very handy site. Question. What size bulb does it use?Also, will and LED bulb work without a resistor? Or is it 'plug n play'?
Re: (MSAGRO)
Posted: Fri Nov 11, 2011 1:33 pm
by 455SD
I haven't looked aftermarket for this, so I personally don't know of anything other than OEM part that will work. Going with Toyota for the parts our Vibes use, is the least expensive. Maybe someone will pipe in with the question about LED usage.Here's the Toyota part number: 90072-02005
