noob install - wiring harness questions
Posted: Wed Nov 09, 2011 5:58 am
Alright, totally a newbie to installing HU's. In fact, prior to this, changing the headlight bulb was something I was very proud of. For reference sake - I have a 2008 Vibe with base factory system. That's all I know - no subs or tweeters.I was given a little Sony HU, and really wasn't going to do much with it, but seems that my factory stereo has decided it doesn't want to give my CD's back when I hit eject. Eventually I can get them out, but thats another story.I've done a pile of research, and I'm all set to do the install. I bought the mounting kit (Single DIN stereo in the double DIN) and the wiring harness and the antenna adapter. Wanting only the best for my Vibe, I snubbed the kits at Walmart and went to the local install guy. Swearing his stuff was better, I paid more for his, only to get home and open up the packaging... and it's all "scosche" stuff. I soldered and shrink tubed all the connections, but I have three orange wires on my harness for illumination that don't have a counterpart on my sony HU. I'm just assuming this means my HU won't dim with the rest of my dashboard? I also have a black wire for ground.On the sony wiring harness, I have a blue wire for the power antenna (which I'm assuming I don't need as my vibe doesn't have a power anntenna) and the ground doesn't terminate in a bare wire like the rest, but in a connector to be bolted to the frame. Here are my questions:1.) Am I right in assuming the orange wires for "illumination" on the Scosche adapter harness is indeed OK to leave unconnected? 2.) Am I right in assuming the blue wire for the Power antenna on the Sony harness can be ignored?3.) Should I cut off the grounding connector on the sony harness and solder it to ground of on the scosche adapter?PS - I've been taking photos each step along the way so perhaps this can be a bit of a guide for someone else looking to make the jump and install their own kit.
