Passenger floor pooling rain water.
Posted: Thu Oct 27, 2011 3:19 am
by RodDoe
I had pulled back the matting on the passenger floor of my 2003 Vibe. There is a hole used to tunnel sensor wiring from the outside to the inside. Rain water is seeping into this hole at a good clip. Not coming from an a/c hose. It seems bizarre that water could pool there. Looked under the car the passed weekend-couldn't see any reason how water would accummulate there. I am not getting it!What the Freak!
Re: Passenger floor pooling rain water. (RodDoe)
Posted: Thu Oct 27, 2011 3:22 am
by ehoff121
Welcome to GenVibe!Just curious, what did you do to rule out the A/C drain hose? Have you had the A/C on at all recently?
Posted: Thu Oct 27, 2011 9:52 am
by star_deceiver
Might you have a sunroof?
Posted: Thu Oct 27, 2011 10:13 am
by RodDoe
Yes I do! Don't see how the rain water is getting in from under the car....(water seeks its own level.) I could see if it were dripping down from the sunroof. Thanks!
Posted: Fri Oct 28, 2011 5:07 am
by cptnsolo77
Last time I had water in the passenger seat, the sunroof drain was blocked. There was a glob of dirt sitting right in the hole.
Posted: Fri Oct 28, 2011 11:41 am
by RodDoe
I do see holes in the sunroof (guess those are for rain drain) that look obstructed with debris. I removed it..... and am keeping my fingers crossed. Thanks!
Re: (RodDoe)
Posted: Fri Oct 28, 2011 11:50 am
by jake75
Egzachery why I am no fan of sunroofs.
Posted: Tue Nov 01, 2011 3:23 am
by RodDoe
Tring to snake a wire down the sunroof drain....snaked about 4 feet down. I cannot push anymore down. Where is the drain suppose to come out from the front passenger side area.
