Sunroof and frame falling away from roof on one side
Posted: Sat Oct 15, 2011 9:58 am
by satin78
my 2005 vibes sunroof is falling in on one side. the sunroof works fine opening and closing but, when shut i can push up on it and it goes up about 1/2 inch, then i let it go and it falls back down. its not leaking and you can see its drooping when you look at the roof line on the exterior of the car. Any ideas, or should i just bring it to the dealer?? Thank You!!
Re: Sunroof and frame falling away from roof on one side (satin78)
Posted: Wed Oct 26, 2011 12:21 am
by the_sarge
If you slide the shade back and look at the right and left outer edges of the sunroof you will see two brackets on each side that attach the glass panel to the blocks in the sunroof track. The screws are of the torx type, and go horizontally into the blocks. It sounds like one or both of these screws are loose--they allow for some adjustment. If that's the case, simply push the roof up until it's where it should be (you may need someone outside the car to eyeball it) and then tighten the screw with a torx driver. Hope this helps.
