2003 sunroof drains on bottom of car
Posted: Wed Oct 12, 2011 12:01 am
by crystal79
Ran water into the drain at the sunroof. Water came out of the bottom of the car in drips along a 2 foot area of the bottom of the car at the seam that runs along the side of the car, and from a spot deeper under the car. Is this normal? I would think there would be a more localized location for the drain? Can anyone describe where the drain is located at the bottom of the car. There was a lot of dirt, pine tree needles, and even whole leaves behind the wheel, so I'm assuming the drain is clogged. Live on a dirt road and park under a pine tree. Thanks so much for your coimments!!!
Re: 2003 sunroof drains on bottom of car (crystal79)
Posted: Wed Oct 12, 2011 11:31 pm
by djkeev
While I've never looked for them, the drains run down the "A" pillar (front door hinge) and the "C" pillar s(rear door latch).I don't know if they drain into the body cavity or if the physically exit the body below these two points. I believe the rear one runs forward and in exiting below the rear seat back ???The front one exits to the front of the A Pillar and behind the front wheel.Sorry I couldn't be of more help but the factory service manual is a little vague on exactly where they exit.Dave
Re: 2003 sunroof drains on bottom of car (djkeev)
Posted: Tue Nov 01, 2011 2:36 am
by RodDoe
Was the interior of your car wet, either on the passenger or driver's side? I am trying to snake a wire down the drain.... hasn't popped out anywhere I can see... and now I can't push anymore wire down.
