Turning off auto headlights ...
Posted: Sun Oct 09, 2011 1:24 pm
If you want to control your headlights manually, there is an easy way to do it...Just pry the sensor out of the dash with two small flathead screwdriver , disconnect it ,seal the end of the connector, push it back partly,tape it together so when you push it back in the dash you do not loose the wire part...Incase you want to reconnect it sometimes...Takes 10 minutes ...
