oil viscosity difference between model years
Posted: Sat Oct 08, 2011 9:12 am
by blackphoenix
When I had my 09 vibe, the manual said to put 5W-20 in. Now in my 2010 vibe, it says to use 5W-30. I am using the same 2.4L engine in both cars. Yet, on my 2010, the oil cap says 5W-20. What is going on here? I think that most new 4 bangers use 5W-20 if I'm not mistaken. Should I change the oil to put 5W-20 in?
Re: oil viscosity difference between model years (blackphoenix)
Posted: Sat Oct 08, 2011 9:21 am
by vibenvy
There have been other threads on here about the 2009 - 2010 manuals saying one viscosity and the oil caps saying another. The general consensus has been to stick with the 5W 20.
Re: oil viscosity difference between model years (J_TO_ENVY)
Posted: Sat Oct 08, 2011 11:03 am
by blackphoenix
Quote, originally posted by J_TO_ENVY »There have been other threads on here about the 2009 - 2010 manuals saying one viscosity and the oil caps saying another. The general consensus has been to stick with the 5W 20.exactly what I thought. Thanks for the info.
Posted: Sat Oct 08, 2011 1:15 pm
by vibenvy
You're very welcome !
Posted: Sun Oct 09, 2011 3:59 am
by journeyforce
I am wondering if it is a printing error in the manual since the cap is the same. To make sure it is the right cap the next time you are around a GM dealership stop and go to the parts dept and ask the part number and what it should say on the cap
Re: oil viscosity difference between model years (journeyforce)
Posted: Mon Oct 10, 2011 1:43 pm
by Vibramatic
The 2010 Owner's manual says 5W-20
Posted: Mon Oct 10, 2011 2:00 pm
by 10vibe
EDIT:Pontiac Vibe manuals:2010 hard copy that came with Vibe (manufactured 5/09):Part No. 20784572 A First Printing 2008 GMOil suggested 5w or 0w-30 GM6094M (wrong)auto transmission fluid WS (correct)Gmownercenter.yahoo.com:2010 pdf:Part No. 20784572 A First Printing 2008 GMOil suggested 5w or 0w-30 GM6094M (wrong)auto transmission fluid WS (correct)Pontiac.com:2010 pdf:Part No. 25823089 B Second Printing 2008 GMoil suggested 5w or 0w-20 GM6094M (correct)auto transmission fluid T-IV (wrong)2009 pdf:Part No. 25823089 B Second Printing 2008 GMoil suggested 5w or 0w-20 GM6094M (correct)auto transmission fluid T-IV (wrong)2008 pdf:Part No. 15863403 A First Printing 2007 GM oil suggested 5w or 0w-30 GM6094M (correct)auto transmission fluid T-IV (correct)2010 oil fill cap on 1.8L suggests 5w or 0w-202010 1.8L auto transmission dipstick indicates WST-IV and WS ATF are incompatible.As for coolant, Dex-Cool (wrong)! Depending on year, either Toyota long life concentrated red or the newer Toyota super long life pink, 50/50 premix. Zerex Asian Phosphated HOAT (P-HOAT or POAT) 50/50 premix might be an acceptable replacement. Other Asian OEM's P-HOAT coolants and Motorcraft deep green P-HOAT would probably be acceptable too.Anybody signed up for a 2009 Vibe at the Gmownercenter.yahoo.com to see which manual they are pushing?
