2009 - Looking for Dome Light pos+ wire
Posted: Sun Sep 25, 2011 8:21 am
by 09Vibe
Can someone point me in the right direction? I'm just looking to add a couple of strips of LED lighting to either side of the front floor area under the dash, every car I've ever owned has had floor illumination, kind of miss it when I drop something at night ! Just don't know where to tap into ... anyone done something similar ? Thanks ....
Re: 2009 - Looking for Dome Light pos+ wire (09Vibe)
Posted: Fri Sep 30, 2011 1:23 pm
by joshuaeb09
As most domelights are - switched I just wired mine to a switch next to the traction control switch. If you really want to you could use a relay, If you look for an alarm installation sheet you should be able to find the - trigger for the domes.
Posted: Sat Oct 01, 2011 12:22 pm
Wish I could help you out right now BUT I will be doing similar LED modding to my Vibe GT over the winter. Hope someone else guides you in the right direction in the meantime
