Radiator fan not working
Posted: Fri Sep 23, 2011 8:17 am
by christo
Hi everybody,I was leaving Quebec City tonight to go back home for the weekend... As a normal friday afternoon, there was traffic going to the bridges where I need to reach.In the traffic, temperature was going up and up... I think that the fan is not working... how to know where the problem is coming from?Thank you,Christo
Re: Radiator fan not working (christo)
Posted: Fri Sep 23, 2011 9:09 pm
by djkeev
First thing, when the engine is cool, open the radiator cap and see if there is any coolant in the system. You may have a leak and if you are low on coolant, no amount of cooling fans will cool off your engine.If you are low on coolant, fill it up, wait, let the bubbles escape and keep filling until it is full. Now, find out why you were low, where is the leak?? Go fix it NOW!!!IF you are full with coolant, start the engine and let it idle until it is fully warm. Before overheating the cooling fan should kick on. Keep an eye on the temp gauge so you don't overheat should it fail to come on.If it doesn't come on, you've got a wire unplugged, a bad fan, a bad fan sensor, a bad relay, a bad fuse......Depending upon your repair skills you can find and fix the problem yourself or take it to a shop and pay them $$'s to fix it for you.Dave
Re: Radiator fan not working (djkeev)
Posted: Fri Sep 23, 2011 11:04 pm
by christo
Hi!Took a look under the hood this morning... I found that my 40A radiator fan fuse is dead... I think it will be ok... I'm going now for replacing the fuse!!Have a nice day!
Posted: Thu Sep 29, 2011 12:31 am
by christo
Fail...My new fuse is already dead... there is a problem somewhere...I will probably need to bring the car to a dealer...
