Any new mods for oil filter on 1.8 engines???
Posted: Tue Sep 20, 2011 12:37 am
by metaxa44
What is the part number for the tool or wrench to use to remove oil filter on 2009 Vibe 1.8 ???Next question is , did anybody come up with a mod.. for different filter or adapter to use regular filter on the car???Thanks..
Re: Any new mods for oil filter on 1.8 engines??? (metaxa44)
Posted: Tue Sep 20, 2011 1:57 am
by star_deceiver
I always forget to ask when I'm at the Toyota dealer. I use a short punch and hammer. Still meaning to buy the proper adaptor....
Posted: Wed Nov 21, 2012 12:07 am
by revstohigh
when i worked at the toyota dealership back in like 03 all the techs had the same spring loaded 2 jaw type .snap on sels a nice one . if your not sure which kind i mean i can take a pic of mine
Posted: Wed Nov 21, 2012 4:47 am
by beemerphile1
After the local auto parts store, Harbor Freight, and Summit Racing, I finally got the correct socket at Walmart for a few bucks. It is a black plastic oil filter socket that handles two different sizes. I have used it several times without problem.
I don't remember the size but if you do a search on here it has been discussed many times.
Posted: Wed Nov 21, 2012 7:26 pm
by star_deceiver
I just bought another strap wrench...
FYI, Toyota sells the part, on special order, for over $100!!! :shock:
Snap-On also sells one, but check around.
Posted: Thu Nov 22, 2012 6:38 am
by Caretaker
I am the man to ask since I have wasted so much money on store brand oil filter wrenches. The answer is 64mm. Here is a link to ebay those who sell the right one.
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40" onclick="window.open(this.href);return false;
This is not sold in any store that I can find. I could not even get Toyota to sell me one. It fits like a glove and is dead on perfect. While you can get a 63mm or 65mm in the store, you can angle it to get the housing to turn for a little while. But in time, it will start spinning on you and drive you nuts.
Posted: Thu Nov 22, 2012 7:12 am
by sideshowalan
Why all the difficulty with removing oil filters? They don't need to be torqued down very far in the first place.
Screw them on until the gasket is up against the engine, then another 1/4 turn, no more is necessary. I've never had a leaky filter or difficulty removing one using this method.
Posted: Thu Nov 22, 2012 7:34 am
by Caretaker
it isn't a filter, it is an outer canister. There is no way you could remove it by hand once the rubber seal makes contact with the metal. It forms a very grippy seal, and takes a tool to properly turn the canister for the final turn; otherwise the oil will seep through.
Posted: Thu Nov 22, 2012 5:15 pm
by Capt.Vibe
Surprised no one has mentioned the Assenmacher service tool. It is sold by Amazon for $16.45 and ships for free if your order is more than $25.00. For us Canadians it's an additional $9.98 shipping for a total of $26.43, still a pretty fair price.
http://www.amazon.com/Assenmacher-Speci ... ssenmacher" onclick="window.open(this.href);return false;
Posted: Sat Nov 24, 2012 7:43 am
by Mark
sideshowalan wrote:Why all the difficulty with removing oil filters? They don't need to be torqued down very far in the first place.
This.
I've never had to use a tool or wrench to get my filter off, cause I don't use one to put it on maybe. Never had a leak either.
Turn it on by hand, turn it off by hand. That works on the Vibe and on the Dodge 6.7 CTD both.
Posted: Sat Nov 24, 2012 7:45 pm
by star_deceiver
@Mark, SideShowAlan
This is the 09-10 1.8L housing. Not a standard filter. Once the o-ring makes contact, it takes about another two full turns to get it seated.
Posted: Sat Nov 24, 2012 8:08 pm
by sideshowalan
Wow that's totally different than the 03-08's.
Thanks for the photos.
Posted: Sun Nov 25, 2012 4:00 pm
by Mark
Well, okey dokey then.
Sorry, I had no idea.
Wonder what they thought was wrong with the good ol' one-piece spin-on oil filter?
Posted: Tue Nov 27, 2012 4:23 pm
by Flip-Side
The 1.8 is extremely sensitive to low oil conditions. Should someone tighten the oil filter improperly there would be leakage. Other than that...no clue. I only go as tight as my hands allow.
Posted: Tue Nov 27, 2012 8:43 pm
by beemerphile1
Even though I have a filter wrench that works, it has slipped on occasion. Eventually the filter cover will wear and the wrench will slip more.
I did some research and discovered the size should be 64.5mm with 14 flutes. I ordered one and have a picture below. Notice the slots which fit over the fins on the filter cover. It is a Laser Tools 5160 oil filter wrench. Here is the manufacturer;
http://www.lasertools.co.uk/item.aspx?cat=0&item=7048
Here is the eBay seller;
http://www.ebay.com/itm/Aluminum-Toyota ... 0467515%26
Posted: Tue Nov 27, 2012 11:20 pm
Hmmmmm. After reading all these posts, I'm glad I have the 2.4L engine :o
Posted: Wed Nov 28, 2012 1:00 pm
by Caretaker
after getting 33 mpgs around town, I'm glad I have the corolla engine. Even though you are right tpollauf; I know why they went to the environmentally kinder paper filter to eliminate more plastic/metal in the landfills, but I'd rather have a screw on filter as well. Nonetheless, it isn't necessary to buy anything fancy. The link I gave to e-bay will get you tons of options for a 64mm 14 fluted housing wrench cup. It doesn't slip. How do I know this? Because I have bought every other damn filter cup under the sun to include ones that kinda fit but started to slip after a while. Don't waste your money on high tech gadgets; just get the 64mm cup.
