Stock 6 CD Radio Wiring Diagram
Posted: Sat Jul 05, 2003 10:01 pm
by retiredfields
Anyone know the wiring diagram colors for the 4 speaker wires at the rear of the stock 6 CD radio? I want to tie in at the rear of the radio for a separate powered bass speaker.Thanks in advance......
Re: Stock 6 CD Radio Wiring Diagram (retiredfields)
Posted: Sat Jul 05, 2003 11:36 pm
by russ257
Posted: Mon Aug 09, 2004 1:29 am
by vibeInCanada
I have the diagram, now which wires would I hook up to my amp for either a sub or a set of 6x9's in the rear? Do I have to split some existing wires?I don't want to lose the existing speakers and amp setup. That is, I want to add another amp.Thanks
Posted: Mon Aug 09, 2004 4:19 am
by Jahntassa
You can just use some T-Taps on the rear speaker wires, or front, depending on what you wanna do. You shouldn't have to cut anything.
Posted: Mon Aug 09, 2004 5:03 am
by vibeInCanada
Forgive my ignorance but what are T-Taps???Would I put these before the factory amplifier (ie] the inputs to the factory amplifier) or after the factory amplifier? (ie] the output of the factory amplifier)Thanks for the quick reply....
