rear drum break
Posted: Tue Aug 30, 2011 2:03 pm
by hapagan
so i was replacing my left rear wheel hub yesterday and everything was going fine until i tried putting the drum back on. it wouldnt fit because one of the brakes on the drum wont return to its original position. its like its stuck as if i had the brakes pushed down all the time. but its just one of them. the other one does go back. idk what to do. i'd appreciate anyone's help.
Re: rear drum break (hapagan)
Posted: Tue Aug 30, 2011 8:26 pm
by keithvibe
Losen up the adjuster on the bottom of the drum so the drum slides on.Then readjust till it has a small amount of drag to it.Edit, I know i'm not the best speller, but brakes, break are two diff things.In this instance, it's brakes.Unless, you are taking a break from your brakes. HAHA
