12v Power Source Controlled By Driving Lights/Turn Signals
Posted: Sun Aug 28, 2011 8:16 am
by A Psycho Martyr
Ok, I know to many of you, this is common sense, but I didn't know, so I'm posting what I found out.If you are doing any accent lighting or anything electrical, you can use the turn signal wiring for a 12v power source.Here's a pic of the wiring:If you use the solid green wire, your add-on will come on with the driving lights...If you use the green w/white stripe wire, your add-on will blink with your turn signals.I know I'm not the only one who has thought of adding turn signals in the mirrors, and now I know to use the green w/white wire for my power source. Just wanted to clarify the difference in the green and green w/white wires.
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (A Psycho Martyr)
Posted: Sun Aug 28, 2011 8:38 am
by DressedInBlack
Good to know. Thanks Brandon! And don't worry, I'm very pedestrian when it comes to things electrical.
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (DressedInBlack)
Posted: Sun Aug 28, 2011 9:08 am
by A Psycho Martyr
I was gonna wait and post before I tried wiring anything to see if anyone knew what was what, but decided to go ahead and try to get it right the 1st time ended up making my Angel Eyes blink with my turn signals.lolthat's how I found this out
Posted: Sun Aug 28, 2011 9:34 am
by joshuaeb09
lol When I had my expedition I used some relay trickery to get my angel eyes to stay on and blink with the turn signals. Was actually pretty cool.
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (joshuaeb09)
Posted: Sun Aug 28, 2011 9:42 am
by A Psycho Martyr
that's pretty neat if mine were another color i may have been interested in that
Posted: Sun Aug 28, 2011 11:57 am
by KITT222
Oh the possibilities!!! Thanks Brandon! This helps a ton. Although I'm not yet sure of how it will help...
Posted: Mon Aug 29, 2011 1:32 am
by lovemyraffe
Great info! Thanks Brandon!
Posted: Fri Oct 07, 2011 11:45 am
by Blanco_Diablo
What is the white wire for?
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (Blanco_Diablo)
Posted: Sat Oct 08, 2011 4:33 am
by Serj22
Thought:Two led light strips under the footwellls. One on the driver side hooked to the driver side turns, then the opposite for the passenger. Result: Blinking footwells for each side...
Re: 12v Power Source Controlled By Driving Lights/Turn Signals (Serj22)
Posted: Tue Oct 11, 2011 3:52 pm
by A Psycho Martyr
then you'd NEVER drive for miles not knowing your blinker was on.lol Good ideaand the white wire is the ground for both greens
