Dimmer does not work-tail lights and shifter lights problem
Posted: Thu Aug 25, 2011 12:28 am
Hi, I have problem with tail lights and shifter lights. Normally, when light switch is off and sensor detects that there is not enough light outside, Vibe turns on lights, including tail lights and shifter lights. Recently it stop doing that. If I turn lights manually, everything works fine. It also looks that light dimmer does not work either.I checked fuses - TAIL fuse is OK. I check dimmer relay under the hood and swapped head light and dimmer relays (the same kind). Headlights work - problems above are still here.Anybody have experience with this problem - any suggestions? Thanks!
