Fuel filter replacement on an 05 Base model?
Posted: Tue Aug 23, 2011 4:33 pm
by Gandalf
I want to replace the fuel filter on my 05 Base Vibe.Where is it located, and are there any tricks to doing the job?I'm hoping it's not inside the gas tank...but i don't see it inside the engine compartment, as I hoped.Generally, for things like this, i have been buying Toyota parts....because they aren't GM
, and I assume it came with a Toyota fuel filter on it.Any reason not to use a Toyota fuel filter? Are there any that will work as well, but cost a little less? I assume the Toyota part is sort of pricey, like they all are, but I haven't checked yet.Any other advice, hints, etc., especially from anyone who has done this, will be greatly appreciated.I've done the fuel filter on a Honda Civic...but it was on the firewall, and extremely easy to get to. I just put a rag over it, when I loosened the fuel line; very little gas came out...no fire. A 15 minute job, at most.Thanks, guys
Re: Fuel filter replacement on an 05 Base model? (Gandalf)
Posted: Tue Aug 23, 2011 10:27 pm
Quote, originally posted by Gandalf »I'm hoping it's not inside the gas tank... Sorrysee if
http://forums.genvibe.com/zerothread?id=37065 helps anyAlso, if you are going to get the filter froma a dealer, then check both GM and Toyota. depending on the part, sometimes Toyota is cheaper than GM, other times GM is cheaper than Toyota. Sometimes by a lotOn these cars changing the fuel filter is typically an "only when needed" item, instead of a regularly scheduled maintenance task. Why do you think yours needs replaced?
Posted: Wed Aug 24, 2011 1:24 am
by lovemyraffe
It isn't as easy as you would hope. The fuel tank is under the rear seat. Like joatmon said, it isn't a regularly scheduled maintenance item. Are you experiencing something that you think would warrant a replacement fuel filter?
Posted: Wed Aug 24, 2011 3:39 am
by ou.grizzly
Non-serviceable fuel filter, aka it is in the gas tank like others have stated.Do not change it unless your fuel filter goes kaput
Posted: Wed Aug 24, 2011 6:11 am
by Gandalf
I wanted to do it because it hasn't been done, and I couldn't find a schedule for replacement.I haven't had any trouble...I just prefer to do more maintenance, and less repair.It's hard to believe that a fuel filter will last as long as the vehicle....but I'm sure not up for removing the gas tank, to get at it.!Thanks, guys.
