cruise control button
Posted: Fri Aug 19, 2011 11:09 am
by Gvibe
'05 Vibe cruise button popped out. Able to get it back in but cruise does not work now. Could not find a fuse for it? Any help would be greatly appreciated.
Re: cruise control button (Gvibe)
Posted: Fri Aug 19, 2011 1:21 pm
by jake75
I can't remember ever reading a post with that issue. Might need a new stalk.
Re: cruise control button (jake75)
Posted: Sat Aug 20, 2011 6:03 am
by Gvibe
Thanks jake 75 for your response. I feel the same way because I have searched the forum and couldn't find a answer. The fuse also controls other electrical componets in the Vibe and they are working. I ordered the sw from RockAuto (my favorite) and with the help from Sublinewinds service manual I should be cruising! I will post my results.
Posted: Wed Aug 24, 2011 10:19 am
by Gvibe
As usual Rock Auto came thru quick. But with two wires not three, horn ground I think. If your cruse button pops out and you get it back in and it doesn't work, on the back side there is a small screw that holds a cover over three slide contacts that the button moves on, one was bent over. I straightened it and I'm sure it would have worked, O'well $40.00 and I have a new one. I hope this helps someone! I have been using this forum for over a year, it is the best of all the forums I have used! Thanks Guys
