Anyone know if this SRI will fit...
Posted: Tue Aug 09, 2011 11:30 am
by Blanco_Diablo
K&N 69-8600TRWill it fit my base 2006 vibe? K & N said they don't make any that fit base vibes. Sounds wrong to me. Any help is greatly appreciated.They claim it fits an '04 base (see fifth row down at link), any reason it wouldn't fit an '06?http://www.knfilters.com/search/appsearch.aspx
Re: Anyone know if this SRI will fit... (Blanco_Diablo)
Posted: Wed Aug 10, 2011 5:36 am
by Blanco_Diablo
Bump, anyone?
Posted: Wed Aug 10, 2011 11:37 am
by hapagan
i thought 03-04s and 05+ had the same engine and components ? it should fit.
Re: (hapagan)
Posted: Wed Aug 10, 2011 12:21 pm
by Kamikaze
you might have to modify it to make it work, but it should work.I'm thinking it has something to do with the DBW, or maybe with the oil breather return line...yeah, thats probably what it is.... that's what I had to do, block the oil breather line off the air intake, and put a breather filter off the head.
Re: (Kamikaze)
Posted: Thu Aug 11, 2011 11:41 am
by Salsa Guy
You mean like liks this? See the silver and white filter?
Posted: Thu Aug 11, 2011 6:19 pm
by Blanco_Diablo
Thanks all, looks like I missed out on the one I was looking at (someone beat me to it on MO.com) but good to know for future reference.
Posted: Thu Aug 11, 2011 10:43 pm
by Salsa Guy
Here's one from Cosmo that should fit.http://www.cosmoracing.com/pro...=1312There are some cheapies on E-bay that will work (like mine) but you'll end up replacing the filter and coupling and will chost you about the same as a Cosmo.
Re: (Salsa Guy)
Posted: Fri Aug 12, 2011 8:29 am
by Blanco_Diablo
Yep, thanks for the reminder... had that one in the back of my mind for a while... still on the list. Just saw the K&N barely used and cheap so thought about pulling the trigger on it if the fit was more straight-forward.
Posted: Fri Aug 12, 2011 1:33 pm
by Salsa Guy
The main thing on a CAI or SRI is that the MAF seals correctly. On the stock air intake any hoses before the MAF, or between the MAF-TB and after the TB stay in those positions on the CAI or SRI. The only exception would be the valve cover breather if your TB or CAI/SRI doesn't have a port for it you'll need to add a filter, like mine.
Re: (Salsa Guy)
Posted: Fri Aug 12, 2011 3:54 pm
by Blanco_Diablo
Gotcha! Thanks man, appreciate the info. Wish more of my fellow genvibers lived in Oregon
