CAI/SR install quandary
Posted: Wed Jul 20, 2011 11:25 pm
by Piggy
Last night I, after much effort and a bit of bracket fabrication, installed a custom Spectre intake (autozone tubes) that I pulled from my old 99 corolla. I triple checked that all my hoses were connected and sensors plugged in. Nothing that was supposed to be attached somewhere was loose. I even made some brackets from aluminum flat to bolt the EVAP valves down. So everything looks great, I turn the key, engine starts, sucks in air and quits. I pulled the brackets off thinking it possible that the valves shouldn't have a ground and was causing an issue, though more likely I'd get a CEL for evap right? I tried giving it gas as soon as it started and it roughly kept going but as soon as I let off the pedal, nada. Fed up, almost out of light and needing a car for today, I put the stock box back on and it runs perfectly.At this point I have only one idea what may have caused this. Does the positioning of the MAF have anything to do with idle/throttle control to the point where, if the sensor is turned the wrong way the car may start but won't continue to run?This is the same setup that my corolla had plus one 60 degree bend.From the TB, 60 deg. bend, MAF port, 90 deg. bend, vacuum hose port, cone filter. If I bother to try it again I'll post a pic of the set upThanks
Re: CAI/SR install quandary (Piggy)
Posted: Thu Jul 21, 2011 2:05 am
by lovemyraffe
Is the CEL on?
Posted: Thu Jul 21, 2011 8:35 am
by MotoAce51
Are all the air lines connected in the correct spot. I think you could have issues if one is hooked up wrong. If I remember correctly there are 3 that need to be disconnected/ reconnected.
Re: (MotoAce51)
Posted: Thu Jul 21, 2011 10:18 am
by Piggy
Well, CEL has been on for over 6 months for 0420. I check it every so often to be safe but it's always 420. I havn't bothered to try a new cat yet. As for connections, all good. I did a little more research mean time and it seems that the MAF has to be positioned just so in the air flow. I won't likely be able to do anything with it till monday though.
