shift problem
Posted: Fri Jul 15, 2011 5:56 pm
I've got an 05' automatic, 55k mi, with a fresh PCM via a recall, installed a couple months back.My problem seems to be on the downshifting when I decelerate. It seems to bog at times before it finally shifts. I was passing through a bumpy intersection so I slowed without braking, and it seemed like it wanted to stall, rather than downshift.CEL is not on. Today I did a drain on the fluid, no change.Could it be the PCM they installed is bad?
