Part numbers for 2010 silver automatic shifter bezels
Posted: Fri Jul 15, 2011 10:00 am
by vibenvy
As some of you 2009 automatic transmission Vibe owners may or may not realize, the black piece around the shift knob that houses the P R N D etc. was changed to silver in 2010 Vibes. After quite a bit of research and final verification from GMPartsCenter.net, I completed this little "modification" to both our 2009 Vibe GTs, so I thought I'd post the part numbers here for anyone who may want to do this to their own 2009 Vibe.
2010 Vibe 4-speed automatic silver shifter bezel: #19205019 = 2009 Vibe 1.8L Base automatic & 2009 Vibe AWD
2010 Vibe 5-speed automatic silver shifter bezel: #19205020 = 2009 Vibe 2.4L Base automatic & 2009 Vibe GT automatic
This is a relatively inexpensive modification costing less than $50.00 shipped for a brand new part. Installation is very easy. Simply unscrew the shift knob, carefully use a small flathead screwdriver to pop the black piece out (there's a small notch right under the household outlet button), pop the new silver piece into place and screw the shift knob back on. Voila! You've got yourself a new, perfectly matched silver interior piece that will add a little more color to the interior of your 2009 Vibe without costing you a ton of money or alot of time.
*Pictures coming soon...
Re: Help needed: can't find part # for 2010 silver shift bezel (J_TO_ENVY)
Posted: Fri Jul 15, 2011 11:37 am
by vibe2.1
try gmpartsdirect.com. click on accessories tab, and enter your vehicle info. $69 plus shipping / handling (which can be expensive).i think what you're looking for is a chrome applique that they call a decal. it's probably a plastic overlay with adhesive tape applied to the back side. they list 2 part nos., depending on transmission RPO.one is probably for manual transmissions, the other for the autos. check your RPO code to be sure.MVD = GM PART # 19171212MVA + MVB = GM PART # 19202931caution: i bet this will reflect sunlight at any angle. i had a car once with chrome trim around the shift lever, similar to this. no matter where the sun was or which direction i was driving, it seemed like the sun always reflected off this trim piece and into my eyes.
Re: Help needed: can't find part # for 2010 silver shift bezel (vibe2.1)
Posted: Fri Jul 15, 2011 9:01 pm
by vibenvy
Quote, originally posted by vibe2.1 »try gmpartsdirect.com. click on accessories tab, and enter your vehicle info. $69 plus shipping / handling (which can be expensive).i think what you're looking for is a chrome applique that they call a decal. it's probably a plastic overlay with adhesive tape applied to the back side. they list 2 part nos., depending on transmission RPO.one is probably for manual transmissions, the other for the autos. check your RPO code to be sure.MVD = GM PART # 19171212MVA + MVB = GM PART # 19202931caution: i bet this will reflect sunlight at any angle. i had a car once with chrome trim around the shift lever, similar to this. no matter where the sun was or which direction i was driving, it seemed like the sun always reflected off this trim piece and into my eyes.Actually, I am not looking for the chrome overlay. I am looking for the silver painted piece that came standard in the 2010 Vibes (shown in the pictures in my original post). In the 2009 Vibes that piece is black. I went through every single category on GMPD and couldn't find anything. I guess I'll just have to go to the dealer and see if they can track it down for me .
Posted: Sat Jul 16, 2011 3:40 am
by vit
Yeah, the piece around the shifter and the center of the shifter knob on my 10 GT are silver.Somebody posted the chrome piece that goes around the shifter, I think that was a bit too much "bling".
Re: (vit)
Posted: Sat Jul 16, 2011 3:49 am
by vibenvy
Quote, originally posted by vit »Yeah, the piece around the shifter and the center of the shifter knob on my 10 GT are silver.Somebody posted the chrome piece that goes around the shifter, I think that was a bit too much "bling".I don't suppose you'd want to trade your silver piece for my black piece ?I don't care for that chrome piece either. I am in the process of trying to get the chrome overlay for the shift knob though because I think that would look good without adding too much bling to the interior.
Posted: Sat Jul 16, 2011 4:00 am
by vit
Can't find the silver.chrome:http://www.crateenginedepot.co...71212
Posted: Sat Jul 16, 2011 4:02 am
by vit
Re: (vit)
Posted: Sat Jul 16, 2011 4:08 am
by vibenvy
Vit, did you get my PM about checking the backside of that piece for a part number?
Posted: Sat Jul 16, 2011 4:50 am
by vit
No, I didn't. I can do that if you tell me how to take it off.
Re: (vit)
Posted: Sat Jul 16, 2011 4:56 am
by vibenvy
Assuming you have a 5-speed auto... unscrew the shift knob and simply use a small flathead screwdriver to pop the silver piece out of place. There is a little notch right under the 115v button to put the screwdriver into to help pop it out of place. Thanks a lot!
Posted: Sat Jul 16, 2011 5:36 am
by vit
Ok, here it is. It's interesting that the part was made in December of '08 according to the date code. These are the oly numbers, the "good side" is painted silver.
Re: (vit)
Posted: Sat Jul 16, 2011 5:45 am
by vibenvy
Thanks for the help vit. I really appreciate it . Mine has the same numbers on it which obviously aren't a part number . My date code is June of 2008 .I think I tracked down the part number on GM Parts Direct though *fingers crossed*. I emailed their customer service to confirm. If it is indeed the correct part, I will be sure to post the number in this thread for any other 09 owner who may want the silver shift bezel.
Posted: Sat Jul 16, 2011 9:44 am
Quote, originally posted by J_TO_ENVY »I am referring to the silver piece that surrounds the shift knob No silver piece on my 09 GT JUST lots of black leather Wait, you have an automatic ..... I knew there was something wrong here Just messing with you Carrie. Good luck on your find and post before/after pics if/when you complete this mod
Re: Help needed: can't find part # for 2010 silver shift bezel (tpollauf)
Posted: Sun Jul 17, 2011 1:20 am
by vibenvy
Quote, originally posted by tpollauf »No silver piece on my 09 GT JUST lots of black leather Wait, you have an automatic ..... I knew there was something wrong here Just messing with you Carrie. Good luck on your find and post before/after pics if/when you complete this mod Hey now ! I rather enjoy getting in the Vibe, putting it in D and taking off without having to do any real "work" . That and I don't even know how to drive a manual . I will definitely post pictures and info when I get this "mod" accompolished. I actually have half of it on its way already from eBay .
Posted: Tue Jul 19, 2011 9:32 am
by vibenvy
I emailed GM Parts Direct yesterday and included a picture of the exact part I was looking for and supplied my VIN. According to them, the technical name for this part is instrument panel extension upper trim panel - gray and the part number is: #19204491. I went ahead and ordered one. It was $62.04 shipped from GMPD. I really hope it is indeed the correct part . Assuming it is, I will of course post pictures once it's installed .* EDIT: The above part number is incorrect. The correct part number is: #19205020 and the name of the piece is transmission shift control selector. It is $44.37 shipped on GM Parts Direct. *
Posted: Mon Aug 01, 2011 8:46 am
by 09vGT
I've thought about doing this, thought not for $62.04
Re: (09vGT)
Posted: Tue Aug 02, 2011 9:26 am
by vibenvy
Quote, originally posted by 09vGT »I've thought about doing this, thought not for $62.04 Yeah, I thought it was a little steep too, but I think it will make a nice difference in the interior and at least I know it will match all the other silver pieces as far as color and texture. Plus it will be much easier to just remove the black one and snap the silver one in its place, rather than trying to paint, etc. .Mine is supposed to be arriving tomorrow so I will be sure and post pictures !
Re: (J_TO_ENVY)
Posted: Thu Aug 04, 2011 8:58 am
by vibenvy
Well, just as I feared they sent me the 2009 black one instead of the 2010 silver one . I just emailed them about possibly returning/exchanging it, but I'm sure they'll probably just tell me I'm SOL.I can say, the price actually isn't bad because you get the entire asembly around the shift knob, including a brand new LED for the shift indicator.
Re: (J_TO_ENVY)
Posted: Thu Aug 04, 2011 9:59 am
by lovemyraffe
I kinda like the black one better. Just my opinion though.
Re: (lovemyraffe)
Posted: Thu Aug 04, 2011 10:13 am
by vibenvy
Quote, originally posted by lovemyraffe »I kinda like the black one better. Just my opinion though.I did too, but the more I look at it, the more I prefer the silver. It adds a little more color to the interior without being too over the top, plus coupled with the chrome shift knob overlay, it will make the interior stand out a bit from all the other 09 Vibes around here (GV).
Re: (J_TO_ENVY)
Posted: Fri Aug 05, 2011 8:13 am
by vibenvy
I edited the post where I had listed the part number given to me by GM Parts Direct. I emailed GMPartsCenter.net last night and this time I believe I truly have the correct part number. The part number is: #19205020. The part is called transmission shift control selector. It is $44.37 shipped from GM Parts Direct.I am just waiting to hear back from GM Parts Direct about whether they'll give me a refund or not. Hopefully they will, then I can turn around and order this part number which will hopefully be the correct part this time .
Posted: Fri Aug 05, 2011 10:15 am
by 09vGT
Post when you find out! I prefer the silver color also. It's just that much more of a customized interior to match the outside.Not as much work as some of our other friends who have red Vibes and try to do the same (ponta), since our interior pieces are already silver! YAY FOR US! !!!!
Re: (09vGT)
Posted: Fri Aug 05, 2011 11:17 am
by vibenvy
Quote, originally posted by 09vGT »Post when you find out! I prefer the silver color also. It's just that much more of a customized interior to match the outside.Not as much work as some of our other friends who have red Vibes and try to do the same (ponta), since our interior pieces are already silver! YAY FOR US! !!!!!I will definitely post when I find out for sure. Yes, I love the silver pieces in the interior, hence my desire for this piece .Liquid Platinum Metallic FTW !
Re: (J_TO_ENVY)
Posted: Fri Aug 12, 2011 11:12 pm
by vibenvy
I just ordered #19205020 from GMPartsCenter.net. The total was: $36.96 + $7.99 handling = $44.95.Hopefully this time it will indeed be the correct part and I will finally be able to post some pictures *fingers crossed*.
Re: (09vGT)
Posted: Sat Aug 13, 2011 2:04 am
Quote, originally posted by 09vGT »Not as much work as some of our other friends who have red Vibes and try to do the same (ponta), since our interior pieces are already silver! YAY FOR US! !!!!Alright ...... take it easy on us RED Vibe owners Silver has it's place in/on automobiles. In fact it is probably the most common color when it comes to two-toning and accenting ALL the other base colors. On my sons Dark Blue Vibe, his pinstripe is silver and If I pinstripe my Red Vibe it too would be silver. Wheels, trim pieces, knobs, etc. all look better if a shade of silver/chrome is applied.
Re: (tpollauf)
Posted: Tue Aug 23, 2011 8:11 am
by vibenvy
#19205020 is the correct part number for the silver shift indicator bezel for the 5-speed automatic transmission.It has a nice smooth surface just like the rest of the silver interior pieces.
Re: (J_TO_ENVY)
Posted: Thu Dec 08, 2011 10:44 pm
by eblend
Anyone know if the silver on the Matrix matches that of the silver on the pontiac? I want to replace my center peice with one from matix. The matrix has a little clock in there, which I don't care for, but there is a spare switch location which I want to utilize with a toyota rav4 heated seats switch. One one side there would be the standard 115v switch, on the other the heated seats switchthis is a pic of the console and a pic of the switch attached
Re: (eblend)
Posted: Sat Dec 10, 2011 1:42 am
by vibenvy
Quote, originally posted by eblend »Anyone know if the silver on the Matrix matches that of the silver on the pontiac?It should be exactly the same color.
Re: Part numbers for 2010 silver automatic shifter bezels
Posted: Sun Apr 05, 2015 3:51 pm
by vibenvy
Okay, so I realize there have been no posts in this thread since December of 2011, but I wanted to revive it by editing the original post to include the part numbers for both the 2010 4-speed and 5-speed automatic silver shifter bezels and adding current pictures that will actually show up. I am also including the information here...
