Fog Lights Stopped Working
Posted: Wed Jul 13, 2011 10:40 am
by jlcolombo
The fog light lens were broken as well as one bulb, the other bulb was working. I fixed the fog light lens with silicon. This worked great. I then replaced the broken bulb 9006. I did not notice if the other bulb was still working prior to replacing the broken bulb. Now both fog lights are not working. I then replaced both bulbs thinking the other bulb was now brokenI check the relay and it seems to be working. I swapped with the horn relay. What else could the problem be? Can you help. 2006 Pontiac Vibe.
