03 AWD vibe won't move
Posted: Wed Jul 06, 2011 5:25 am
by 03awdVibe
Hey guys, I have an auto 03 awd vibe with ~175k miles and it won't move when in any gear at all. Before this all happened, the car would make a high pitched kind of whine only when i was on the gas and would stop when i took my foot off the gas. I was on the freeway when all of this was happening, and as soon as i exited and reached a stop sign, the car wouldn't move in drive or reverse anymore. It would only rev up. I started the car up again the day after and tried to move it to the front of my house, and it magically worked again, but only for about 5 seconds, then there was once again no power, but only in reverse. When in reverse, the car feels as if it's in park and would only rev up to 2.5k RPM. When i put it in Drive you can hear the *thump* as it engages in the gear. Any suggestions/help would be appreciated.
Posted: Wed Jul 06, 2011 6:01 am
by ou.grizzly
Need a new trans
Re: (ou.grizzly)
Posted: Wed Jul 06, 2011 10:10 am
by star_deceiver
Fluid level? Sounds like very low transmission fluid or something in the valve body is fubar!
Re: 03 AWD vibe won't move (03awdVibe)
Posted: Thu Jul 07, 2011 11:14 am
by Salsa Guy
Wyhen's the last time you had the Tranny serviced, Transfer Case, Rear Diff?
Re: 03 AWD vibe won't move (Salsa Guy)
Posted: Thu Jul 07, 2011 11:18 am
by CAMOGIRL
Sounds like when the trans in my Heep went out... I had 1st gear only and it wouldn't get up to full speed in that gear, felt bogged down like you describe. I had to be replaced...
Re: 03 AWD vibe won't move (CAMOGIRL)
Posted: Fri Jul 08, 2011 4:03 am
I'd at least check the fluid level in the tranny firstQuote, originally posted by CAMOGIRL » I had to be replaced...impossible. you cannot be replaced
Re: 03 AWD vibe won't move (joatmon)
Posted: Fri Jul 08, 2011 4:25 am
by jkm311
Quote, originally posted by joatmon »impossible. you cannot be replaced Brilliant.
Posted: Mon Dec 26, 2011 7:21 am
by vibe5264
I realize this is an old thread, but what did it turn out to be? This EXACTLY is happening to me!But, I have the fwd...
Posted: Mon Jan 02, 2012 9:54 pm
by vibe5264
it was the ECU. Getting replaced now...
Posted: Thu Jan 05, 2012 11:26 am
by vibe5264
I'm sorry for replying so many times, but I feel like this shouldn't be an edit. It turns out it was NOT the ECU, it was actually LED taillights/brakelights I had put in. For whatever reason, the difference in resistance caused my computer to "lose communication" with my transmission. This caused my ECU to malfunction, but the dealership said it was reset and we took the bulbs out after two weeks of trying to figure this out and sure enough it did it!
